Integer in uint8_t minute() schreiben
Hallo,
wieder mal ne blöde Frage wie so oft.
Ist es möglich in der RTClib, now.minute() einen Integer Wert zuzuweisen?
Die Libary sagt:
class DateTime {
public:
  DateTime(uint32_t t = SECONDS_FROM_1970_TO_2000);
  DateTime(uint16_t year, uint8_t month, uint8_t day, uint8_t hour = 0,
           uint8_t min = 0, uint8_t sec = 0);
  DateTime(const DateTime &copy);
  DateTime(const char *date, const char *time);
  DateTime(const __FlashStringHelper *date, const __FlashStringHelper *time);
  DateTime(const char *iso8601date);
  bool isValid() const;
  char *toString(char *buffer) const;
uint8_t minute() const { return mm; }
      @brief  Return the second.
      @return Second (0--59).
Soweit ich das vertsehe nicht, da es const ist oder?
Geht mir um den sqw Pin vom DS3231 für einen Interrupt:
Hier mein Code und was ich machen will:
/* Example implementation of an alarm using DS3231
   VCC and GND of RTC should be connected to some power source
   SDA, SCL of RTC should be connected to SDA, SCL of arduino
   SQW should be connected to CLOCK_INTERRUPT_PIN
   CLOCK_INTERRUPT_PIN needs to work with interrupts
#include <RTClib.h>
// #include <Wire.h>
RTC_DS3231 rtc;
int interval = 2;
DateTime now;
int mins;
int timex;
// the pin that is connected to SQW
#define CLOCK_INTERRUPT_PIN 2
  // initializing the rtc
  if (!rtc.begin()) {
    Serial.println("Couldn't find RTC!");
    Serial.flush();
    abort();
  if (rtc.lostPower()) {
    // this will adjust to the date and time at compilation
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  //we don't need the 32K Pin, so disable it
  rtc.disable32K();
  // Making it so, that the alarm will trigger an interrupt
  pinMode(CLOCK_INTERRUPT_PIN, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(CLOCK_INTERRUPT_PIN), onAlarm, FALLING);
  // set alarm 1, 2 flag to false (so alarm 1, 2 didn't happen so far)
  // if not done, this easily leads to problems, as both register aren't reset on reboot/recompile
  rtc.clearAlarm(1);
  rtc.clearAlarm(2);
  // stop oscillating signals at SQW Pin
  // otherwise setAlarm1 will fail
  rtc.writeSqwPinMode(DS3231_OFF);
  // turn off alarm 2 (in case it isn't off already)
  // again, this isn't done at reboot, so a previously set alarm could easily go overlooked
  rtc.disableAlarm(2);
  now = rtc.now();
  mins = now.minute();
  mins = mins + interval;
  mins = mins % 60;
  now.minute = mins;
  // schedule an alarm 10 seconds in the future
  if (!rtc.setAlarm1(now, DS3231_A1_Minutes // this mode triggers the alarm when the seconds match. See Doxygen for other options
    Serial.println("Error, alarm wasn't set!");
    Serial.println("Alarm will happen in xx seconds!");
  // print current time
  char date[10] = "hh:mm:ss";
  rtc.now().toString(date);
  Serial.print(date);
  // the value at SQW-Pin (because of pullup 1 means no alarm)
  Serial.print(" SQW: ");
  Serial.print(digitalRead(CLOCK_INTERRUPT_PIN));
  // whether a alarm happened happened
  Serial.print(" Alarm1: ");
  Serial.print(rtc.alarmFired(1));
  // Serial.print(" Alarm2: ");
  // Serial.println(rtc.alarmFired(2));
  // control register values (see https://datasheets.maximintegrated.com/en/ds/DS3231.pdf page 13)
  // Serial.print(" Control: 0b");
  // Serial.println(read_i2c_register(DS3231_ADDRESS, DS3231_CONTROL), BIN);
  // resetting SQW and alarm 1 flag
  // using setAlarm1, the next alarm could now be configurated
  if (rtc.alarmFired(1)) {
    rtc.clearAlarm(1);
    Serial.println("Alarm cleared");
    Serial.println("Bew Alarm");
    if (mins >= 60) mins = mins - 60;
    now.minute() = mins;
  delay(2000);
void onAlarm() {
  Serial.println("Alarm occured!");
/*static uint8_t read_i2c_register(uint8_t addr, uint8_t reg) {
    Wire.beginTransmission(addr);
    Wire.write((byte)reg);
    Wire.endTransmission();
    Wire.requestFrom(addr, (byte)1);
    return Wire.read();
Danke an jeden der sich die Zeit nimmt mir zu helfen!
Schönen Tag
Lg
minute() ist keine Variable, sondern eine "getter-Funktion", die dir den Wert der internen Variablen mm read-only liefert. Insofern kannst du - egal was - auch nicht minute zuweisen.
Die einzigen Methoden, den Wert zu ändern, sind die zum Setzen der Zeit in RTC.h.
Eine Minute als int zu deklarieren, würde übrigens nur sinnvoll sein, wenn die Minutenwerte auch negativ werden könnten, was bei der Zeit einer Echtzeituhr eher unwahrscheinlich ist. Du solltest überlegen, was du da eigentlich bezwecken willst.
ok danke, dann geht das so nicht.
Würde gerne die aktuelle Zeit im Setup vor dem Alarm speichern und dann im loop verwenden können.
Wenn ich eine globale Variable anlege und dort dann den int Wert der sekunden oder minuten im setup reinschreibe, ist diese Variable im loop immer 0.
Lg
Wolltest Du den ESP32 nicht Schlafen legen?
Eventuell hilft Dir diese Addition einer Zeitspanne, getestet mit ESP32:
#include <RTClib.h>
RTC_DS3231 rtc;
DateTime zeit;
  Serial.println("\nStart ...");
  if (!rtc.begin()) {
    Serial.flush();
    abort();
  char buf[60] = {"\0"};
  zeit = rtc.now();
  snprintf( buf, sizeof(buf), "   Zeit:  %u:%0u:%0u", zeit.hour(), zeit.minute(), zeit.second() );
  Serial.println(buf);
  zeit = zeit + TimeSpan(0, 0, 5, 0);
  snprintf( buf, sizeof(buf), "Zukunft:  %u:%0u:%0u", zeit.hour(), zeit.minute(), zeit.second() );
  delay(100);
now.minute = mins;
Wieso willst Du die aktuelle Zeit, die Du vom RTC holst verändern? Entweder setzt Du die RTC mit der neuen Zeit oder verwendest einen Satz Variablen für Deine privat-Zeit.
Grüße Uwe
Gibt es dafür ein Beispiel?
Das kann ich nicht bestätigen:
// ESP32
#include <RTClib.h>
RTC_DS3231 DS3231;
DateTime zeit;  // Anlage einer globalen Datenstruktur
// globale Variablen
uint8_t meineStunde = 0;
uint8_t meineMinute = 0;
uint8_t meineSekunde = 0;
uint8_t zukunftStunde = 0;
uint8_t zukunftMinute = 0;
uint8_t zukunftSekunde = 0;
bool einmal = true;
  if (!DS3231.begin()) {
    Serial.flush();
    abort();
  zeit = DS3231.now();  // die Zeitstruktur bekommt eine Zeit zugewiesen
  Serial.printf("   Zeit:  %2u:%02u:%02u\n", zeit.hour(), zeit.minute(), zeit.second() );
  meineStunde = zeit.hour();     // eine einzelne Variable, unüblich
  meineMinute = zeit.minute();   // eine einzelne Variable, unüblich
  meineSekunde = zeit.second();  // eine einzelne Variable, unüblich
  zeit = zeit + TimeSpan(0, 0, 5, 0);  // rechnen mit einer Zeitstruktur, hier 5 Minuten addieren
  Serial.printf("Zukunft:  %2u:%02u:%02u\n", zeit.hour(), zeit.minute(), zeit.second() );
  zukunftStunde = zeit.hour();
  zukunftMinute = zeit.minute();
  zukunftSekunde = zeit.second();
  if (einmal)
    einmal = false;
    Serial.printf("Zukunft in loop: %2u:%02u:%02u\n", zeit.hour(), zeit.minute(), zeit.second() );    // globale Struktur
    Serial.printf("     meine Zeit: %2u:%02u:%02u\n", meineStunde, meineMinute, meineSekunde);        // globale Variablen
    Serial.printf("zukünftige Zeit: %2u:%02u:%02u\n", zukunftStunde, zukunftMinute, zukunftSekunde);  // globale Variablen
  delay(100);
Danke an alle für die Antworten und Hilfe.
Es funktioniert jetzt auch einfach so, anscheinend muss ich irgendwo einen Fehler gehabt haben und nicht gesehen oder gefunden.
Hab jetzt die Variablen neu definiert und nochmals versucht und es hat funktioniert.
Dadurch hat sich auch mein Problem mit dem RTC Interrupt gelöst, da ich endlich die Zeit richtig angezeigt bekommen habe und gewusst was passiert.
Aber mal wirklich danke an alle die immer so nett sind und mir/uns hier helfen!
Ist nicht selbstverständlich.
Jetzt funktioniert mal alles was ich bis her wollte.
Nochmals herzlichen dank und schönen Abend!!!
Lg
