I am currently trying to program between two APC220 radio transceivers. And when I write an if statement that triggers when the correct integer is received the integer always changes so the if statement is always triggered.
The transmitter: (This seems to work)
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 50;
const int switchPin = 2;
int state = LOW;
int lastButtonState = HIGH;
int ledState = LOW;
int reading;
int x = 2;
pinMode(switchPin, INPUT);
reading = digitalRead(switchPin);
if (reading != lastButtonState){
lastDebounceTime = millis();
lastButtonState = reading;
if ((millis() - lastDebounceTime) > debounceDelay){
if(state != lastButtonState){
state = lastButtonState;
if (state == HIGH) {
Serial.print(2);}
The receiver: In this code the y integer changes to five when I run the code, even though I cant see how this is possible. With this code it prints a 2 and a 5 when the button on the transmitter is clicked
(I used y=5 in this test just to make sure it wasn't working)
int x=1;
char data;
while(Serial.available()>0){
data = Serial.read();
int y = int(data)-48;
Serial.println(y);
if (y = 5){
Serial.println(y);
I'm new to Arduino (and coding as a whole) so sorry if it's a simple mistake that I've made.
