Integrate and include Adafruit_Sensor.h> #include "Adafruit_BMP280.h" the 0.95 inch RGB OLED with this C++ program for Arduino, you will need to inc
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_SSD1331.h> // OLED library
#define OLED_DC 6 // OLED Data/Command pin
#define OLED_CS 10 // OLED Chip Select pin
#define OLED_CLK 13 // OLED Clock pin
#define OLED_MOSI 11 // OLED MOSI (Master Out Slave In) pin
#define OLED_RESET 9 // OLED Reset pin
Adafruit_BMP280 bmp; // I2C
Adafruit_SSD1331 display = Adafruit_SSD1331(OLED_DC, OLED_CS, OLED_CLK, OLED_MOSI, OLED_RESET);
float pressure; // To store the barometric pressure (Pa)
float temperature; // To store the temperature (oC)
float altitude; // To store the altitude (m)
Serial.begin(9600); // Initialize serial communication
display.begin(); // Initialize OLED display
if (!bmp.begin()) { // Initialize sensor
Serial.println("Could not find a valid BMP280 sensor, check wiring!");
while (1);
// Read and store sensor data
pressure = bmp.readPressure();
temperature = bmp.readTemperature();
altitude = bmp.readAltitude(SEALEVELPRESSURE_HPA);
// Print sensor data to serial monitor
Serial.print("Pressure: ");
Serial.print(pressure);
Serial.println(" Pa");
Serial.print("Temperature: ");
Serial.print(temperature);
Serial.println(" oC");
Serial.print("Altitude: ");
Serial.print(altitude);
Serial.println(" m");
// Update OLED display
display.setCursor(0,0); // Set cursor to top left corner of OLED
display.print("Pressure: ");
display.print(pressure);
display.print(" Pa");
display.setCursor(0,8); // Set cursor to next line of OLED
display.print("Temp: ");
display.print(temperature);
display.print(" oC");
display.setCursor(0,16); // Set cursor to next line of OLED
display.print("Altitude: ");
display.print(altitude);
display.print(" m");
delay(5000); // Delay between updates
When is our homework due?
