Hello, newbie here, just learning arduino. Any help appreciated
Am trying to copy a part of a sketch and integrate it into my main sketch but am having issues getting it to work, this is the code im trying to integrate -
unsigned long previousMillis = 0; // Stores last time relay was updated
const long interval = 60000; // Interval at which to cycle relay (60 seconds)
float percentageTimeOn = 0.0; // Percentage of time relay is on (0% by default)
pinMode(CONTROLLINO_R0, OUTPUT);
Ethernet.begin(mac);
connectToMqtt();
if (!client.connected()) {
connectToMqtt();
client.loop();
if (currentMillis - previousMillis >= (interval * percentageTimeOn)) {
digitalWrite(CONTROLLINO_R0, LOW); // Turn relay off
if (currentMillis - previousMillis >= interval) {
digitalWrite(CONTROLLINO_R0, HIGH); // Turn relay on
// Multiply percentageTimeOn by 100 and publish as number
float percent = percentageTimeOn * 100;
char percentageTimeOnString[8];
dtostrf(percent, 2, 1, percentageTimeOnString); // Convert float to string with 1 decimal
client.publish(mqtt_topicpub, percentageTimeOnString);
void mqttCallback(char* topic, byte* payload, unsigned int length) {
// Convert payload to string
char msg[5];
if (length < 4) { // Assuming the percentage won't be more than 3 digits
strncpy(msg, (char*)payload, length);
msg[length] = '\0';
percentageTimeOn = constrain(atof(msg) / 100.0, 0.0, 1.0); // Convert to fraction and constrain between 0 and 1
And i want to integrate it into this one -
#include <Controllino.h>
#include <Ethernet.h>
#include <PubSubClient.h>
#include <TinyGPS++.h>
#include <SPI.h>
#include <SoftwareSerial.h>
#define RELAY_R0 CONTROLLINO_R0
#define RELAY_R1 CONTROLLINO_R1
#define RELAY_R2 CONTROLLINO_R2
#define RELAY_R3 CONTROLLINO_R3
#define MQTT_SERVER "broker.hivemq.com"
#define MQTT_PORT 1883
#define MQTT_USERNAME "randy"
#define MQTT_PASSWORD "123456"
#define TOPIC_SUB "testpivotcode"
#define TOPIC_PUB "testpivotcodepub"
// Define the MQTT payload values for each relay
#define FORWARD "Forward"
#define REVERSE "Reverse"
#define PIVOTON "Pivot ON"
#define PIVOTOFF "Pivot OFF"
// Define the momentary duration in milliseconds
#define MOMENTARY_DURATION 1000
byte mac[] = {
random(0, 255),
random(0, 255),
random(0, 255),
random(0, 255),
random(0, 255),
random(0, 255)
EthernetClient ethClient;
PubSubClient client(ethClient);
setup1();
loop1();
void setup1() {
pinMode(RELAY_R1, OUTPUT);
pinMode(RELAY_R2, OUTPUT);
pinMode(RELAY_R3, OUTPUT);
client.setServer(MQTT_SERVER, MQTT_PORT);
client.setCallback(callback);
void loop1() {
reconnect();
client.loop();
// MQTT callback function
void callback(char* topic, byte* payload, unsigned int length) {
// Convert the payload to a string
String message = "";
for (int i = 0; i < length; i++) {
message += (char)payload[i];
// Check the payload for each relay
if (message.equals(FORWARD)) {
digitalWrite(RELAY_R1, HIGH);
delay(MOMENTARY_DURATION);
digitalWrite(RELAY_R1, LOW);
} else if (message.equals(REVERSE)) {
digitalWrite(RELAY_R2, HIGH);
digitalWrite(RELAY_R2, LOW);
} else if (message.equals(PIVOTON)) {
digitalWrite(RELAY_R3, HIGH);
} else if (message.equals(PIVOTOFF)) {
digitalWrite(RELAY_R3, LOW);
void reconnect() {
while (!client.connected()) {
if (client.connect("test", MQTT_USERNAME, MQTT_PASSWORD)) {
client.subscribe(TOPIC_SUB);
Thanks in advance for any help.
