integrating 2 codes
hi I’m trying to add the following LED code into the dodging robot code by jcar
int LED = 12;
pinMode (LED,OUTPUT);
digitalWrite(LED,HIGH);
digitalWrite(LED,LOW);
where should place this code for both the robot and LED to work
//Ultrasonic sensor pins
#define TRIG 9
#define ECHO 10
//motor module pins
const int channel_a_enable = 6;
const int channel_a_input_1 = 4;
const int channel_a_input_2 = 7;
const int channel_b_enable = 5;
const int channel_b_input_3 = 3;
const int channel_b_input_4 = 2;
int a=0; //motor a speed and direction
int b=0; //motor b speed and direction
int phase=0; //what stage are we up to
long timeout=0; //how long have we been doing it for
#define PROX 30
#define FORWARDSPEED 150
#define REVERSESPEED 150
//set TURNSPEED negative to turn the other way
#define TURNSPEED 150
#define REVERSETIME 1000
#define TURNTIME 1000
pinMode(11,OUTPUT);
digitalWrite(11,LOW); //GND for ultrasonic
pinMode(8,OUTPUT);
digitalWrite(8,HIGH); //5V for ultrasonic
usonicsetup();
pinMode( channel_a_enable, OUTPUT ); // Channel A enable
pinMode( channel_a_input_1, OUTPUT ); // Channel A input 1
pinMode( channel_a_input_2, OUTPUT ); // Channel A input 2
pinMode( channel_b_enable, OUTPUT ); // Channel B enable
pinMode( channel_b_input_3, OUTPUT ); // Channel B input 3
pinMode( channel_b_input_4, OUTPUT ); // Channel B input 4
//everything off
digitalWrite( channel_a_input_1, LOW);
digitalWrite( channel_a_input_2, LOW);
digitalWrite( channel_a_enable, LOW);
digitalWrite( channel_b_input_3, LOW);
digitalWrite( channel_b_input_4, LOW);
digitalWrite( channel_b_enable, LOW);
delay(1000); //wait a bit
Serial.begin( 9600 ); //serial debug
Serial.println(“Starting up”);
//read ultrasonic sensor
int d;
d=usonic(11600)/58; // distance in cm
if(d==0){d=200;}
Serial.println(d); //print d on serial monitor
//react based on d
switch(phase){
case 0:
if(d<PROX){phase=1;timeout=millis();} //if too close, reverse
case 1:
if(millis()>timeout+REVERSETIME){phase=2;timeout=millis();} //reversed for REVERSETIME, now turn
case 2:
if(millis()>timeout+TURNTIME){phase=0;} //turned for TURNTIME, now back to forward
//print phase for debugging
Serial.print(“PHASE:”);
Serial.println(phase);
//set motors based on stage
switch(phase){
case 0: //normal going forward
a=FORWARDSPEED;
b=FORWARDSPEED;
case 1: //backing up
a=-(REVERSESPEED);
b=-(REVERSESPEED);
case 2: //turn a little
a=TURNSPEED;
b=-(TURNSPEED);
default: //something wrong happened
a=0;
b=0;
setmotor();
delay(200); //wait a bit
void setmotor(){
int s;
if(a>0){
digitalWrite( channel_a_input_1, HIGH);
if(a<0){
digitalWrite( channel_a_input_2, HIGH);
if(b>0){
digitalWrite( channel_b_input_3, HIGH);
if(b<0){
digitalWrite( channel_b_input_4, HIGH);
s=abs(a);
if(s>255){s=255;}
if(s<0){s=0;}
analogWrite( channel_a_enable, s);
s=abs(b);
if(s>255){s=255;}
if(s<0){s=0;}
analogWrite( channel_b_enable, s);
void allInputsOff()
void usonicsetup(void){
pinMode(ECHO, INPUT);
pinMode(TRIG, OUTPUT);
digitalWrite(TRIG, LOW);
long usonic(long utimeout){ //utimeout is maximum time to wait for return in us
long b;
if(digitalRead(ECHO)==HIGH){return 0;} //if echo line is still low from last result, return 0;
digitalWrite(TRIG, HIGH); //send trigger pulse
delay(1);
long utimer=micros();
while((digitalRead(ECHO)==LOW)&&((micros()-utimer)<1000)){} //wait for pin state to change- return starts after 460us typically
utimer=micros();
while((digitalRead(ECHO)==HIGH)&&((micros()-utimer)<utimeout)){} //wait for pin state to change
b=micros()-utimer;
return b;
thanks for your help
In the trash can.
You can not have two processes which use the delay call to work at the same time.
You have to eliminate the delay and implement your code as a state machine.
See my
http://www.thebox.myzen.co.uk/Tutorial/State_Machine.html
Or Robin2's several things at once
However if you just want to flash an LED and are not worried too much about the accuracy of the flash time add this to the start of your loop function.
if(millis() & 0x200) digitalWrite(LED,HIGH); else digitalWrite(LED,LOW);
having put
in your start up function, and
byte LED = 12;
Just before you define your start up function.
Grumpy_Mike:
In the trash can.
Can't resist!
+1 :grinning: :grinning: :grinning:
Yeah, look!
Before you can integrate two codes, you need to understand them. Once you do that it can all fall into place. :sunglasses:
