I start working on a project and I got stuck when I tried to add a servo but I am not good at coding, any help?
This is the project : http://educ8s.tv/arduino-rfid-tutorial/
and on top of that I add the servo that should move when RFID reads the tag.
#include <Servo.h>
#include <MFRC522.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <SPI.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define SS_PIN 10
#define RST_PIN 9
MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
boolean card;
MFRC522::MIFARE_Key key;
int code[] = {236, 52, 228, 140}; //This is the stored UID
int codeRead = 0;
String uidString;
////SERVO settings
Servo myservo;
myservo.attach(3);
myservo.write(0);
Serial.print("Message : ");
Serial.println("Authorized access");
delay(300);
myservo.write(180);
delay(900);
myservo.write(0);
myservo.write(180);
SPI.begin(); // Init SPI bus
rfid.PCD_Init(); // Init MFRC522
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // initialize with the I2C addr 0x3D (for the 128x64)
// Clear the buffer.
display.clearDisplay();
display.display();
display.setTextColor(WHITE); // or BLACK);
display.setTextSize(2);
display.setCursor(10, 0);
display.print("RFID Lock");
display.display();
if ( rfid.PICC_IsNewCardPresent())
readRFID();
delay(100);
void readRFID()
rfid.PICC_ReadCardSerial();
Serial.print(F("\nPICC type: "));
MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak);
Serial.println(rfid.PICC_GetTypeName(piccType));
// Check is the PICC of Classic MIFARE type
if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI &&
piccType != MFRC522::PICC_TYPE_MIFARE_1K &&
piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
Serial.println(F("Your tag is not of type MIFARE Classic."));
return;
clearUID();
Serial.println("Scanned PICC's UID:");
printDec(rfid.uid.uidByte, rfid.uid.size);
uidString = String(rfid.uid.uidByte[0]) + " " + String(rfid.uid.uidByte[1]) + " " + String(rfid.uid.uidByte[2]) + " " + String(rfid.uid.uidByte[3]);
printUID();
int i = 0;
boolean match = true;
while (i < rfid.uid.size)
if (!(rfid.uid.uidByte[i] == code[i]))
match = false;
i++;
if (match)
Serial.println("\nI know this card!");
printUnlockMessage();
} else
Serial.println("\nUnknown Card");
// Halt PICC
rfid.PICC_HaltA();
// Stop encryption on PCD
rfid.PCD_StopCrypto1();
void printDec(byte * buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], DEC);
void clearUID()
display.setTextColor(BLACK); // or BLACK);
display.setTextSize(1);
display.setCursor(30, 20);
display.print(uidString);
display.display();
void printUID()
display.setCursor(0, 20);
display.print("UID:Alex ");
display.display();
void printUnlockMessage()
display.display();
display.display();
display.print("Unlocked");
display.display();
display.display();
Following the code above, the RFID reads and shows Unlocked on my OLED screen but the servo does not want to move, earlier it was moving right when plugged into a bank battery or laptop but not when I scan the tag. I think I have not added the proper code. I don't get any errors it's just not working.
I cant figure it out. I think a should add myservo.write(180) somewhere to link it with RFID tag reading but thats just a presumption, like I said I`m clueless.
Thank you for trying to help me, guys. I will try more tomorrow, have a good day.
