Part 2
The second Part Main code.
//Terms of use
//THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
//IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
//FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
//AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER Now adjusted outputs for the Blue Board V1
//LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, D2 = Left Direction, D3 = Left Step, D4 = Rifgt Direction, D5 = Right Step
//OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
//THE SOFTWARE.
#include <Wire.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
int gyro_address = 0x68; //MPU-6050 I2C address (0x68 or 0x69)
int acc_calibration_value = 1000; //Enter the accelerometer calibration value
//Various settings
float pid_p_gain = 15; //Gain setting for the P-controller (15)
float pid_i_gain = 1.5; //Gain setting for the I-controller (1.5)
float pid_d_gain = 30; //Gain setting for the D-controller (30)
float turning_speed = 30; //Turning speed (20)
float max_target_speed = 150; //Max target speed (100)
byte start, received_byte, low_bat;
int left_motor, throttle_left_motor, throttle_counter_left_motor, throttle_left_motor_memory;
int right_motor, throttle_right_motor, throttle_counter_right_motor, throttle_right_motor_memory;
int battery_voltage;
int receive_counter;
int gyro_pitch_data_raw, gyro_yaw_data_raw, accelerometer_data_raw;
long gyro_yaw_calibration_value, gyro_pitch_calibration_value;
unsigned long loop_timer;
float angle_gyro, angle_acc, angle, self_balance_pid_setpoint;
float pid_error_temp, pid_i_mem, pid_setpoint, gyro_input, pid_output, pid_last_d_error;
float pid_output_left, pid_output_right;
mySerial.begin(9600);
Wire.begin();
TWBR = 12;
received_byte = 14;
TCCR2A = 0;
TCCR2B = 0;
TIMSK2 |= (1 << OCIE2A);
TCCR2B |= (1 << CS21);
OCR2A = 39;
TCCR2A |= (1 << WGM21);
Wire.beginTransmission(gyro_address);
Wire.write(0x6B);
Wire.write(0x00);
Wire.endTransmission();
Wire.write(0x1B);
Wire.write(0x00);
Wire.write(0x1C);
Wire.write(0x08);
Wire.write(0x1A);
Wire.write(0x03);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(13, OUTPUT);
for (receive_counter = 0; receive_counter < 500; receive_counter++) {
if (receive_counter % 15 == 0)digitalWrite(13, !digitalRead(13));
Wire.write(0x43);
Wire.requestFrom(gyro_address, 4);
gyro_yaw_calibration_value += Wire.read() << 8 | Wire.read();
gyro_pitch_calibration_value += Wire.read() << 8 | Wire.read();
delayMicroseconds(3700);
gyro_pitch_calibration_value /= 500;
gyro_yaw_calibration_value /= 500;
loop_timer = micros() + 4000;
if (mySerial.available()) {
received_byte = mySerial.read();
Serial.print(" Now ");
Serial.println(received_byte);
battery_voltage = (analogRead(0) * 1.222);
if (battery_voltage < 1050 && battery_voltage > 800) {
digitalWrite(13, HIGH);
low_bat = 1;
Wire.write(0x3F);
Wire.requestFrom(gyro_address, 2);
accelerometer_data_raw = Wire.read() << 8 | Wire.read();
accelerometer_data_raw += acc_calibration_value;
if (accelerometer_data_raw > 8200)accelerometer_data_raw = 8200;
if (accelerometer_data_raw < -8200)accelerometer_data_raw = -8200;
angle_acc = asin((float)accelerometer_data_raw / 8200.0) * 57.296;
if (start == 0 && angle_acc > -0.5 && angle_acc < 0.5) {
angle_gyro = angle_acc;
start = 1;
Wire.write(0x43);
gyro_yaw_data_raw = Wire.read() << 8 | Wire.read();
gyro_pitch_data_raw = Wire.read() << 8 | Wire.read();
gyro_pitch_data_raw -= gyro_pitch_calibration_value;
angle_gyro += gyro_pitch_data_raw * 0.000031;
gyro_yaw_data_raw -= gyro_yaw_calibration_value;
//Uncomment the following line to make the compensation active
//angle_gyro -= gyro_yaw_data_raw * 0.0000003;
angle_gyro = angle_gyro * 0.9996 + angle_acc * 0.0004;
pid_error_temp = angle_gyro - self_balance_pid_setpoint - pid_setpoint;
if (pid_output > 10 || pid_output < -10)pid_error_temp += pid_output * 0.015 ;
pid_i_mem += pid_i_gain * pid_error_temp;
if (pid_i_mem > 400)pid_i_mem = 400;
else if (pid_i_mem < -400)pid_i_mem = -400;
//Calculate the PID output value
pid_output = pid_p_gain * pid_error_temp + pid_i_mem + pid_d_gain * (pid_error_temp - pid_last_d_error);
if (pid_output > 400)pid_output = 400;
else if (pid_output < -400)pid_output = -400;
pid_last_d_error = pid_error_temp;
if (pid_output < 5 && pid_output > -5)pid_output = 0;
if (angle_gyro > 30 || angle_gyro < -30 || start == 0 || low_bat == 1) {
pid_output = 0;
pid_i_mem = 0;
start = 0;
self_balance_pid_setpoint = 0;
pid_output_left = pid_output;
pid_output_right = pid_output;
switch (received_byte) {
case 1:
pid_output_left += turning_speed;
pid_output_right -= turning_speed;
case 2:
pid_output_left -= turning_speed;
pid_output_right += turning_speed;
case 4:
if (pid_setpoint > -2.5)pid_setpoint -= 0.05;
if (pid_output > max_target_speed * -1)pid_setpoint -= 0.005;
case 8:
if (pid_setpoint < 2.5)pid_setpoint += 0.05;
if (pid_output < max_target_speed)pid_setpoint += 0.005;
case 12:
if (pid_setpoint > 0.5)pid_setpoint -= 0.05;
else if (pid_setpoint < -0.5)pid_setpoint += 0.05;
else pid_setpoint = 0;
if (pid_setpoint == 0) {
if (pid_output < 0)self_balance_pid_setpoint += 0.0015;
if (pid_output > 0)self_balance_pid_setpoint -= 0.0015;
if (pid_output_left > 0)pid_output_left = 405 - (1 / (pid_output_left + 9)) * 5500;
else if (pid_output_left < 0)pid_output_left = -405 - (1 / (pid_output_left - 9)) * 5500;
if (pid_output_right > 0)pid_output_right = 405 - (1 / (pid_output_right + 9)) * 5500;
else if (pid_output_right < 0)pid_output_right = -405 - (1 / (pid_output_right - 9)) * 5500;
if (pid_output_left > 0)left_motor = 400 - pid_output_left;
else if (pid_output_left < 0)left_motor = -400 - pid_output_left;
else left_motor = 0;
if (pid_output_right > 0)right_motor = 400 - pid_output_right;
else if (pid_output_right < 0)right_motor = -400 - pid_output_right;
else right_motor = 0;
throttle_left_motor = left_motor;
throttle_right_motor = right_motor;
while (loop_timer > micros());
loop_timer += 4000;
ISR(TIMER2_COMPA_vect) {
throttle_counter_left_motor ++;
if (throttle_counter_left_motor > throttle_left_motor_memory) {
throttle_counter_left_motor = 0;
throttle_left_motor_memory = throttle_left_motor;
if (throttle_left_motor_memory < 0) {
PORTD &= 0b11111011;
throttle_left_motor_memory *= -1;
else PORTD |= 0b00000100;
else if (throttle_counter_left_motor == 1)PORTD |= 0b00001000;
else if (throttle_counter_left_motor == 2)PORTD &= 0b11110111;
throttle_counter_right_motor ++;
if (throttle_counter_right_motor > throttle_right_motor_memory) {
throttle_counter_right_motor = 0;
throttle_right_motor_memory = throttle_right_motor;
if (throttle_right_motor_memory < 0) {
PORTD |= 0b00010000;
throttle_right_motor_memory *= -1;
else PORTD &= 0b11101111;
else if (throttle_counter_right_motor == 1)PORTD |= 0b00100000;
else if (throttle_counter_right_motor == 2)PORTD &= 0b11011111;
Regards Antony.
