Integrating Server Sketch and Client Sketch
I am trying to make a sketch with a client and a server running at the same time. The client part of the sketch will poll a smart citizen kit for outside weather conditions. The server part of the sketch will listen for commands sent to its IP to turn up or down the temperature setting. I have the two sketches running separately and am looking to integrate them.
I show relevant pieces of the client and server programs below. There seems to be some overlaps which may make it difficult to use both in the same sketch. Can you look at the two pieces of code below and let me know about these questions?
  1. The client sketch defines a server variable (the website address) and the server sketch listens for a client (something connecting to its IP). So both the server and client sketches have server and client objects (or variables). Is this possible to have? Any tips for dealing with that? Will just changing the conflicting "client" and "server" variable names be enough?
  2. The client sketch checks for a connection on port 80 to see if connected to the server. The server sketch opens a server object on port 80. What other port numbers would be OK?
The Client Sketch uses:
char server[] = "api.smartcitizen.me";
WiFiClient client;
if (client.connect(server, 80)) {      /*connected to server */
        client.println("Host: api.smartcitizen.me");
        client.println("Connection: close");
while (client.available()) {
    char c = client.read();    }
  client.stop();
The Server Sketch uses:
    WiFiServer server(80);
    server.begin();
    WiFiClient client = server.available();
        while (client.connected()) {
             if (client.available()) {
    client.stop(); // close the connection:
Some combined server/client test code
//zoomkat 10-02-14, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send a g to test client GET and
//see what the arduino client/server receives
//web page buttons make pins high/low
//use the ' in html instead of " to prevent having to escape the "
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //assign arduino mac address
byte ip[] = {192, 168, 1, 102 }; // ip in lan assigned to arduino
byte gateway[] = {192, 168, 1, 1 }; // internet access via router
byte subnet[] = {255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port arduino server will use
EthernetClient client;
char serverName[] = "checkip.dyndns.com"; // (DNS) dyndns web page server
//byte serverName[] = { 208, 104, 2, 86 }; // (IP) zoomkat web page server IP address
String readString; //used by server to capture GET request
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  pinMode(6, OUTPUT); //pin selected to control
  pinMode(7, OUTPUT); //pin selected to control
  pinMode(8, OUTPUT); //pin selected to control
  //pinMode(5, OUTPUT); //pin 5 selected to control
  Ethernet.begin(mac,ip,gateway,gateway,subnet);
  server.begin();
  Serial.println(F("server/client 1.0 test 9/02/14")); // keep track of what is loaded
  Serial.println(F("Send a g in serial monitor to test client")); // what to do to test client
void loop(){
  // check for serial input
  if (Serial.available() > 0)
    byte inChar;
    inChar = Serial.read();
    if(inChar == 'g')
      sendGET(); // call client sendGET function
  if (client) {
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.print(readString); //print to serial monitor for debuging
            //now output HTML data header
          if(readString.indexOf('?') >=0) { //don't send new page
            client.println(F("HTTP/1.1 204 Zoomkat"));
            client.println();
            client.println();
          else {
            client.println(F("HTTP/1.1 200 OK")); //send new page on browser request
            client.println(F("Content-Type: text/html"));
            client.println();
            client.println(F("<HTML>"));
            client.println(F("<HEAD>"));
            client.println(F("<TITLE>Arduino GET test page</TITLE>"));
            client.println(F("</HEAD>"));
            client.println(F("<BODY>"));
            client.println(F("<H1>Zoomkat's simple Arduino 1.0 button</H1>"));
            // DIY buttons
            client.println(F("Pin5"));
            client.println(F("<a href=/?on2 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off3 target=inlineframe>OFF</a>
            client.println(F("Pin6"));
            client.println(F("<a href=/?on4 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off5 target=inlineframe>OFF</a>
            client.println(F("Pin7"));
            client.println(F("<a href=/?on6 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off7 target=inlineframe>OFF</a>
            client.println(F("Pin8"));
            client.println(F("<a href=/?on8 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off9 target=inlineframe>OFF</a>
            client.println(F("Pins"));
            client.println(F("&nbsp;<a href=/?off2468 target=inlineframe>ALL ON</a>"));
            client.println(F("&nbsp;<a href=/?off3579 target=inlineframe>ALL OFF</a>"));
            client.println(F("<IFRAME name=inlineframe style='display:none'>"));
            client.println(F("</IFRAME>"));
            client.println(F("</BODY>"));
            client.println(F("</HTML>"));
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf('2') >0)//checks for 2
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println(F("Led 5 On"));
          if(readString.indexOf('3') >0)//checks for 3
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println(F("Led 5 Off"));
          if(readString.indexOf('4') >0)//checks for 4
            digitalWrite(6, HIGH);    // set pin 6 high
            Serial.println(F("Led 6 On"));
          if(readString.indexOf('5') >0)//checks for 5
            digitalWrite(6, LOW);    // set pin 6 low
            Serial.println(F("Led 6 Off"));
          if(readString.indexOf('6') >0)//checks for 6
            digitalWrite(7, HIGH);    // set pin 7 high
            Serial.println(F("Led 7 On"));
          if(readString.indexOf('7') >0)//checks for 7
            digitalWrite(7, LOW);    // set pin 7 low
            Serial.println(F("Led 7 Off"));
          if(readString.indexOf('8') >0)//checks for 8
            digitalWrite(8, HIGH);    // set pin 8 high
            Serial.println(F("Led 8 On"));
          if(readString.indexOf('9') >0)//checks for 9
            digitalWrite(8, LOW);    // set pin 8 low
            Serial.println(F("Led 8 Off"));
          //clearing string for next read
          readString="";
void sendGET() //client function to send and receive GET data from external server.
  if (client.connect(serverName, 80)) {
    Serial.println(F("connected"));
    client.println(F("GET / HTTP/1.1"));
    client.println(F("Host: checkip.dyndns.com"));
    client.println(F("Connection: close"));
    client.println();
  else {
    Serial.println(F("connection failed"));
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read(); //gets byte from ethernet buffer
    readString += c; //places captured byte in readString
  //Serial.println();
  client.stop(); //stop client
  Serial.println(F("client disconnected."));
  Serial.println(F("Data from server captured in readString:"));
  Serial.print(readString); //prints readString to serial monitor
  Serial.println(F("End of readString"));
  Serial.println(F("=================="));
  readString=""; //clear readString variable
The Ethernet classes support multiple connections - server and client. The WiFi classes do not.
