Guys , may i request help on combining my project code ?
The project is base on a home security system.
I want to add in a accelerometer in the transmitter board working together with the PIR sensor with OR then the signal will be receive at the receiver board causing the led and buzzer to activate.
(I need help to combine the accelerometer with the transmitter board , any trigger in the accelerometer/PIR sensor will cause the led and buzzer to activate at the receiver board.)
The first and 2nd code consist of transmitter board with PIR sensor and receiver code with LED and buzzer .
This is the Transmitter board which i want to add the accelerometer with:
(The Led help to check whether the PIR sensor is working)
// Include VirtualWire library
#include <VirtualWire.h>
int led_pin = 7;
int transmit_pin = 12;
int pir_pin = 10;
int val = 0;
int pir_state = LOW;
vw_set_tx_pin(transmit_pin);
vw_setup(4000); // Transmission rate
pinMode(led_pin, OUTPUT);
pinMode(pir_pin,INPUT);
char msg[1] = {'0'};
// Get sensor value
val = digitalRead(pir_pin);
// Change message if motion is detected
if (val == 1)
msg[0] = '1';
digitalWrite(led_pin, HIGH); // Flash a light to show transmitting
vw_send((uint8_t *)msg, 1);
vw_wait_tx(); // Wait until the whole message is gone
if (pir_state == LOW)
Serial.println("Hey Stanley Motion detected!");
pir_state = HIGH;
msg[0] = '0';
digitalWrite(led_pin, LOW);
if (pir_state == HIGH)
Serial.println("Bye Stanley Motion ended!");
pir_state = LOW;
This is the receiver board which will receiver signal from the transmitter board when the accelerometer/PIR sensor detect anything:
//Include VirtualWire library
// Pins definition
const int led_pin = 13;
const int receive_pin = 12;
int pinSpeaker = 10;
Serial.begin(9600); // Debugging only
// Initialise the IO and ISR
vw_set_rx_pin(receive_pin);
// Start the receiver PLL
vw_rx_start();
// Set LED pin and Buzzer
pinMode(pinSpeaker, OUTPUT);
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
// Check if a message was received
if (vw_get_message(buf, &buflen))
if(buf[0]=='1')
Serial.println("Motion detected!");
digitalWrite(led_pin,1);
playTone(300, 160);
delay(150);
if(buf[0]=='0')
Serial.println("Motion ended!");
digitalWrite(led_pin,0);
playTone(0, 0);
delay(300);
// duration in mSecs, frequency in hertz
void playTone(long duration, int freq)
duration *= 1000;
int period = (1.0 / freq) * 1000000;
long elapsed_time = 0;
while (elapsed_time < duration)
digitalWrite(pinSpeaker,HIGH);
delayMicroseconds(period / 2);
digitalWrite(pinSpeaker, LOW);
elapsed_time += (period);
This is the Accelerometer which i need help to combine with the transmitter board , any trigger in the accelerometer/PIR sensor will cause the led and buzzer to activate at the receiver board:
#include <ADXL345.h>
#include <a_adxl345.h>
// adxl345demo.ino
// This demo make use of non standard libraries
// - i2c
// - delays
// Connect up adxl345 appropriately using i2c
// After uploading to the MCU, Run the Serial Monitor set to 57600 bps.
// It will show the x, y and z acceleration at 0.5s intervals.
#include "Wire.h"
#include "a_delays.h"
#include "a_i2c.h"
#include "a_adxl345.h"
#define ADXL345_ADDR 0x53
#define FULL_RES 1 // 1 for 0.004g per bit, 0 depends on range
#define RANGE 16 // 2, 4, 8, 16g
static DELAYMS_T adly;
boolean accelInitOK;
int buzzerPin =9;
void taskAccel_init( void ) {
uint8_t id;
if ((id = adxl345Init(ADXL345_ADDR, FULL_RES, RANGE)) == 0) {
Serial.println("Error initializing adxl345");
accelInitOK = false;
return;
else {
adly.dlySet(500);
Serial.print("ADXL345 device ID = ");
Serial.println(id, HEX);
accelInitOK = true;
Serial.println("G in x y z directions:");
void taskAccel ( void ) {
char buf[10];
String temp;
float trigger;
accel_result_t r;
int count = 0;
if (accelInitOK == false)
return;
if (adly.dlyExpired())
adly.dlySetSinceOld(500); // 0.5s interval
if (adxl345Read( &r ) == true)
Serial.println("");
dtostrf(r.x, 5, 2, buf);
temp = String(buf);
trigger = temp.toFloat();
if((trigger>0.1)||(trigger<0.005))
tone(buzzerPin, 100);
noTone(buzzerPin);
Serial.print(buf);
Serial.print(' ');
dtostrf(r.y, 5, 2, buf);
temp = String(buf);
tone(buzzerPin, 31);
noTone(buzzerPin);
Serial.print(buf);
Serial.print(' ');
dtostrf(r.z, 5, 2, buf);
temp = String(buf);
if((trigger>1.5)||(trigger<0.01))
noTone(buzzerPin);
Serial.print(buf);
void setup( void ) {
i2cInit();
Serial.begin(57600);
Serial.println("adxl345 demo program");
taskAccel_init();
void loop( void ) {
taskAccel();
