I have two programs that work fine (thanks to the programs that we copied and modified to some extent) but when I try to combine these two programs, the LCD display the information for one scan cycle and then a bunch of junk appears. I am trying to get this up and running for my 4H student. Here is the code.
#include <Ultrasonic.h>
#include <Servo.h>
#include <LiquidCrystal.h>
Servo servoLeft;
Servo servoRight;
LiquidCrystal LCD(11, 12, 8, 6, 3, 2); //Create Liquid Crystal Object called LCD
float pingTime; //time for ping to travel from sensor to target and return
float targetDistance; //Distance to Target in inches
float speedOfSound=776.5; //Speed of sound in miles per hour when temp is 77 degrees.
int trigPin=10; //Sensor Trip pin connected to Arduino pin 10
int echoPin=9; //Sensor Echo pin connected to Arduino pin 9
int myCounter=0; //declare your variable myCounter and set to 0
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(7, INPUT); // Set right whisker pin to input
pinMode(5, INPUT); // Set left whisker pin to input
servoLeft.attach(13); // Attach left signal to pin 13
servoRight.attach(12); // Attach right signal to pin 12
LCD.begin(16,2); //Tell Arduino to start your 16 column 2 row LCD
LCD.setCursor(0,0); //Set LCD cursor to upper left corner, column 0, row 0
LCD.print(“Target Distance:”); //Print Message on First Row
tone(4, 500, 1000); // Play tone for 1 second
delay(1000); // Delay to finish tone
void loop(){
digitalWrite(trigPin, LOW); //Set trigger pin low
delayMicroseconds(2000); //Let signal settle
digitalWrite(trigPin, HIGH); //Set trigPin high
delayMicroseconds(15); //Delay in high state
digitalWrite(trigPin, LOW); //ping has now been sent
delayMicroseconds(10); //Delay in high state
pingTime = pulseIn(echoPin, HIGH); //pingTime is presented in microceconds
pingTime=pingTime/1000000; //convert pingTime to seconds by dividing by 1000000 (microseconds in a second)
pingTime=pingTime/3600; //convert pingtime to hourse by dividing by 3600 (seconds in an hour)
targetDistance= speedOfSound * pingTime; //This will be in miles, since speed of sound was miles per hour
targetDistance=targetDistance/2; //Remember ping travels to target and back from target, so you must divide by 2 for actual target distance.
targetDistance= targetDistance*63360; //Convert miles to inches by multipling by 63360 (inches per mile)
LCD.setCursor(0,1); //Set cursor to first column of second row
LCD.print(" “); //Print blanks to clear the row
LCD.setCursor(0,1); //Set Cursor again to first column of second row
LCD.print(targetDistance); //Print measured distance
LCD.print(” inches"); //Print your units.
delay(250); //pause to let things settle
void backward(int time);
void forward(int time);
void turnLeft(int time);
void turnRight(int time);
byte wLeft = digitalRead(5); // Copy left result to wLeft
byte wRight = digitalRead(7); // Copy right result to wRight
if((wLeft == 0) && (wRight == 0)) // If both whiskers contact
backward(1000); // Back up 1 second
turnLeft(800); // Turn left about 120 degrees
else if(wLeft == 0) // If only left whisker contact
turnRight(400); // Turn right about 60 degrees
else if(wRight == 0) // If only right whisker contact
turnLeft(400); // Turn left about 60 degrees
else // Otherwise, no whisker contact
forward(20); // Forward 1/50 of a second
servoLeft.writeMicroseconds(1700);
servoRight.writeMicroseconds(1300);
delay(time);
servoLeft.writeMicroseconds(1300); // Left wheel clockwise
servoRight.writeMicroseconds(1300); // Right wheel clockwise
delay(time); // Maneuver for time ms
void turnRight(int time) // Right turn function
servoLeft.writeMicroseconds(1700); // Left wheel counterclockwise
servoRight.writeMicroseconds(1700); // Right wheel counterclockwise
void backward(int time) // Backward function
