Hello
Just received Arduino Expansion board for Edison and followed start-up procedure to the end with no issues,ie., updated firmware and installed Windows 64 drivers.
- Installed Intel i686 boards in Arduino boards manager as required (1.6.2+1.0).
- Compiled and uploaded blinky successfully.
When attempting to compile with my sketches known to run without issues on [Teensy 3.2 or 3.6] I get the following errors:
Any help would be appreciated . . . . . . . Thanks in advance,
Ken
Arduino: 1.6.11 (Windows 10), TD: 1.33, Board: "IntelĀ® Edison"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\kward\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\kward\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\kward\Documents\Arduino\libraries -fqbn=Intel:i686:izmir_ec -ide-version=10611 -build-path C:\Users\kward\AppData\Local\Temp\builde2a962bf4a68a035901e5366477f3f77.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.sketchUploader.path=C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.core2-32-poky-linux.path=C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0 -verbose C:\Users\kward\Documents\Arduino\Processing_Transfer_Sketch_3\Processing_Transfer_Sketch_3.ino\Processing_Transfer_Sketch_3.ino.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\kward\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\kward\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\kward\Documents\Arduino\libraries -fqbn=Intel:i686:izmir_ec -ide-version=10611 -build-path C:\Users\kward\AppData\Local\Temp\builde2a962bf4a68a035901e5366477f3f77.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.sketchUploader.path=C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\sketchUploader\1.6.2+1.0 -prefs=runtime.tools.core2-32-poky-linux.path=C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0 -verbose C:\Users\kward\Documents\Arduino\Processing_Transfer_Sketch_3\Processing_Transfer_Sketch_3.ino\Processing_Transfer_Sketch_3.ino.ino
Using board 'izmir_ec' from platform in folder: C:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0
Using core 'arduino' from platform in folder: C:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0
Warning: Board Intel:i686:izmir_ec doesn't define a 'build.board' preference. Auto-set to: I686_IZMIR_EC
WARNING: Category '' in library DallasTemperature is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library EEPROM is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Ethernet is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library EthernetShield is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library OneWire is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SD is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SPI is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library Servo is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library SoftwareServo is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library TimerOne is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library USBHost is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library WiFi is not valid. Setting to 'Uncategorized'
Warning: platform.txt from core 'Arduino i686 Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
Detecting libraries used...
"C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux/i586-poky-linux-g++" -m32 -march=i586 "--sysroot=C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/core2-32-poky-linux" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -D__ARDUINO_X86__ -w -x c++ -E -CC -march=i686 -m32 -DARDUINO=10611 "-IC:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\cores\arduino" "-IC:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\variants\edison_fab_c" "C:\Users\kward\AppData\Local\Temp\builde2a962bf4a68a035901e5366477f3f77.tmp\sketch\Processing_Transfer_Sketch_3.ino.ino.cpp" -o "nul"
"C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux/i586-poky-linux-g++" -m32 -march=i586 "--sysroot=C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/core2-32-poky-linux" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -D__ARDUINO_X86__ -w -x c++ -E -CC -march=i686 -m32 -DARDUINO=10611 "-IC:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\cores\arduino" "-IC:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\variants\edison_fab_c" "-IC:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\libraries\SPI\src" "C:\Users\kward\AppData\Local\Temp\builde2a962bf4a68a035901e5366477f3f77.tmp\sketch\Processing_Transfer_Sketch_3.ino.ino.cpp" -o "nul"
"C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux/i586-poky-linux-g++" -m32 -march=i586 "--sysroot=C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/core2-32-poky-linux" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -D__ARDUINO_X86__ -w -x c++ -E -CC -march=i686 -m32 -DARDUINO=10611 "-IC:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\cores\arduino" "-IC:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\variants\edison_fab_c" "-IC:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\libraries\SPI\src" "-IC:\Users\kward\Documents\Arduino\libraries\ILI9341_t3DMA" "C:\Users\kward\AppData\Local\Temp\builde2a962bf4a68a035901e5366477f3f77.tmp\sketch\Processing_Transfer_Sketch_3.ino.ino.cpp" -o "nul"
"C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/pokysdk/usr/bin/i586-poky-linux/i586-poky-linux-g++" -m32 -march=i586 "--sysroot=C:\Users\kward\AppData\Local\Arduino15\packages\Intel\tools\core2-32-poky-linux\1.6.2+1.0/core2-32-poky-linux" -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -D__ARDUINO_X86__ -w -x c++ -E -CC -march=i686 -m32 -DARDUINO=10611 "-IC:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\cores\arduino" "-IC:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\variants\edison_fab_c" "-IC:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\libraries\SPI\src" "-IC:\Users\kward\Documents\Arduino\libraries\ILI9341_t3DMA" "C:\Users\kward\AppData\Local\Temp\builde2a962bf4a68a035901e5366477f3f77.tmp\sketch\Processing_Transfer_Sketch_3.ino.ino.cpp" -o "C:\Users\kward\AppData\Local\Temp\builde2a962bf4a68a035901e5366477f3f77.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\kward\Documents\Arduino\Processing_Transfer_Sketch_3\Processing_Transfer_Sketch_3.ino\Processing_Transfer_Sketch_3.ino.ino:3:0:
C:\Users\kward\Documents\Arduino\libraries\ILI9341_t3DMA/ILI9341_t3DMA.h:29:24: fatal error: DMAChannel.h: No such file or directory
#include <DMAChannel.h>
compilation terminated.
Using library SPI at version 1.0 in folder: C:\Users\kward\AppData\Local\Arduino15\packages\Intel\hardware\i686\1.6.2+1.0\libraries\SPI
Using library ILI9341_t3DMA in folder: C:\Users\kward\Documents\Arduino\libraries\ILI9341_t3DMA (legacy)
exit status 1
Error compiling for board IntelĀ® Edison.
