Intel Galileo LCD problem
Hi, I have been trying to get an Intel Galileo to display the LCD example "Hello world". All that I get is black squares and no text at all.
I have used the exact same code and wired it the exact same way on an Arduino UNO and it works perfectly.
I cant figure out what could be wrong?
Below is the code I am using.. any suggestions would be great!
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(20, 4);
  // Print a message to the LCD.
  lcd.print("Hello world");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
Have you adjusted the display using a pot so that it is not displaying squares when it is just turned on?
Have you tried to move setCursor() function to setup()??
Try this:
  lcd.begin(20, 4);
