Interesting fact re MotoMama with 298
Hi all,
I bought a MotoMama shield the other day and tested it tonight. As you may know it uses a 298.
I didn't bother with a sketch in the Uno, just used the Uno as a 5v power supply to the logic side of the MM board, and breadboarded some other 5v and ground lines to hard wire the motor enable and direction.
Then I hooked up a "toy" 3v motor and a 2x AA power pack and expected to see the motor spin. Nothing.
Dismantled, put 3v on the motor, and it ran.
So then read the MM datasheet more carefully, it says the motor input must be 3.3v minimum; measured my 2x AAs at 3.2.
Then I dug out my 6v Magician motors and their battery pack (measured at 6.2 iirc), put one in in place of the 3v motor and 3.2v supply and it ran as advertised.
Moral of the story... when the MM datasheet says 3.3v minimum, they really mean that. (Interesting that, since the motors themselves ran fine with the 3.2.... obviously something in the MM or 298 that prevents output under 3.3.)
Anyway, now I know that both channels of the MM board are good and both Magician motors run in both directions....
This is just how it is. Every tutorial should mention that it can not be used with low voltage motors.
Hi, More info on the MotorMama here, including Manual and Schematic Diagram: http://goo.gl/dC0B2
DISCLAIMER: Mentioned stuff from my own shop...
Interestingly that link mentions 6v minimum, while the MM guys say 3.3. Certainly mine didn't fire at 3.2 and worked at 6 and a bit (I forget exact reading.) But if it really needs 6V- as opposed to say 5.8- then I'll have to make sure my 4x AAs are freshly picked.
FYI, That link links to the MM manufacturer's current datasheet which is for MM V1- they're shipping V2 but I don't know what the differences are.
Actually the "6V" was my opinion, not a spec. Just so many people have problems running 4.5V motors from 5V etc etc..
Bit slow on the uptake.... just realised you're (half of) YourDuino, Terry...
