Hello,
Been trying to reduce my sketch size for past couple days, and I noticed really interesting thing with unsigned longs, but cannot figure out what is actually happening. I had these two lines in my code:
Variable types: byteDoorsOpened - uint8_t, ulLightTurnOffTime - uint32_t. Now with these two lines in my code, sketch is using 19913 bytes. I modified my code so now I only need this one line:
Now sketch is using 19865 bytes, that's 48 bytes lesser, nice. So I thought why the heck ulLightTurnOffTime += LIGHT_TURN_OFF_TIME uses ~40 bytes (assuming few bytes is used for if statement), therefore, just for the interest, I tried to write same incrementing line without if statement, like this:
Surprisingly, sketch size was reduced by 2 bytes, now it's using only 19863 bytes. So now I'm wondering, why adding one more line of code reduces sketch size by 2 bytes, but writing them with if else statements, it increases sketch size by 48 bytes?
it shouldn't be surprising that eliminating the if statement simplifies and reduces the size of the code. it's not a matter of lines, but what those lines are coded to do.
i don't see a difference between the 2 lines w/o the if statements and the 1 line. the compiler can optimize the code to perform one addition, 2 * LIGHT_TURN_OFF_TIME, instead of doing 2 additions
Yeah, I took a look at assembly output, and things got more clear. I'm not familiar with AVR assembly, and never knew how 32-bit variables works in 8-bit CPU , but now I understood that it takes 4 load instructions to load 32-bit variable into register, which uses 16 bytes of storage space, same for storing 32-bit value from register to variable, thus 32 bytes in total.
Code with if-else statement loads and stores ulLightTurnOffTime variable one more time, plus instructions for if-else statement and I guess that's where I'm loosing 48 bytes of program storage space.
For the code with 2 lines w/o the if-else statement, you explained that exactly as I saw it in assembly code, it just adds 30000 instead of 15000.
