Interesting Syntax glitch
I ran across an interesting observation... this WILL compile:
class Object
  public:
  private:
void evaluateScores(Object* a, Object* b);
but this won't:
class Object
  public:
  private:
void evaluateScores( Object* a, Object* b)
*notice the whitespace in the function before Object a in the 2nd example
can anyone tell me why that matters? Is the compiler particularly fussy when it comes to function prototypes matching and whitespace? I never noticed before, because this compiles:
class Object
  public:
  private:
void evaluateScores(int a, int b);
void evaluateScores( int a, int b)
Weird...to my knowledge, any C based language doesn't have a problem with whitespace...
What error is produced?
sketch_feb25b.ino:4:22: error: variable or field 'evaluateScores' declared void
sketch_feb25b.ino:4:22: error: 'Object' was not declared in this scope
sketch_feb25b.ino:4:30: error: 'a' was not declared in this scope
sketch_feb25b.ino:4:33: error: 'Object' was not declared in this scope
sketch_feb25b.ino:4:41: error: 'b' was not declared in this scope
Error compiling.
version 1.6.3
Why is it seeing line 41? I don't see that many.
The failed example compiles for me, with IDE 1.6.6
aarg: Why is it seeing line 41? I don't see that many.
I guess the 'bug' was dealt with!
BulldogLowell: I guess the 'bug' was dealt with!
While at the same time making it impossible to program a Pro Micro. :(
Fails in 1.6.5 too.
Preprocessed version:
#line 1 "sketch_feb26a.ino"
#include "Arduino.h"
void setup();
void loop();
void evaluateScores( Object* a, Object* b);  // <<< Generated (unnecessary) prototype placed too early
#line 1
class Object
  public:
  private:
oqibidipo: Fails in 1.6.5 too.
thanks. it actually took me a while to figure out why i was getting compiler error.
BulldogLowell: I ran across an interesting observation... this WILL compile:
That's VERY strange. I also have the problem you described.
Now, here's something interesting: If I put the whitespace in the FIRST occurrence of "evaluateScores", then it compiles.
If I put a whitespace between the function name and the opening parentheses, it fails! If I match both lines (that is, the SAME whitespaces), it compiles.
Then I tried it with a Makefile and AVR-GCC v4.9.3 (i.e. not using the IDE at all) and STILL have the problem, so it's a GCC bug, not an IDE bug.
For what it's worth.......
Smells of a regular expression problem.
Ditto.
