Hello I want to use an arduino to read data from 2 ADCs (MCP3008). At some points I may want to run the ADCs at 10kHz per channel, which will bring in a total 160 000 sample per second. Can this be done? Is it tricky?
I want to pipe all this data into flash memory/an SD card reader? Again, this uses SPI, am I sill ok?
I have a few Unos lying around, will this be sufficient or do I need to use another Arduino?
