Robin2:
Seems like we have another member who prefers a grievance to a solution.How about posting a link to the datasheet for the device you want help with with.
Also, I assume from the tone of your responses that you are not a newbie and that you will already have written some code to try to work with the device. Post the program that represents your best attempt and tell us exactly what it does and what you want it to do that is different.
...R
hi!
i am sorry if it seemed liked i prefer grievance to a solution!
so i attach the code , library and the datasheet of the device i have been trying to work with.
i have problem when i have been trying to give a signal of frequencies greater than 3-4 hz , i have not been able to get enough samples even after setting the sampling rate to the max!
AD7193.cpp (10.1 KB)
AD7193.h (2.68 KB)
AD7193.pdf (614 KB)
AD7193_Voltage_measure_modified.ino (1.05 KB)
