Hello everyone!
I need to interface the ATMega8a with Arduino Uno to read information from ATMega8a the using ICSP conector.
The ATMEGA8A has MOSI, MISO and CLK pins, how could I connect it to the Arduino Uno to read information?
Actually I don“t want to upload anything to ATMEGA8A, I only need to check how this processor works and capture some data usning ICSP interface. I will take alook at these links, thank you dear avr_fred!
You can't "just capture data from the ICSP interface." To get data from the ATmega8 to the Uno, you'll need to write a sketch for the ATmega8 to read and respond as an SPI slave device. And you'll probably need at least one pin beyond the ISP connector, because you need a "slave select" signal where the ISP connector has only "reset"...
