Hey guys,
Could someone point me to a resource? I want take the data I am gathering in the arduino serial monitor and send it to a separate java program, that will then use that data for its program. But, I'm not certain where to begin. Thanks.
-S
Or using Python?
You problem seems to be getting your data out of the Arduino over Serial.
With a program called Processing you can save data to a text file.
If you have a PC some folks use a program called Gobetweeno.
Most PC programming languages have the ability to read and write data to a serial port which is all that is needed to collect data from or send data to an Arduino.
If you are already familiar with Java it shouldn't be difficult. I don't like Java but I routinely use JRuby which is a version of Ruby that runs on the JVM. As somebody else mentioned, Python is another option, and probably more common.
...R
could someone post some examples or a link to one? Thanks.
Google arduino python
...R
SteveRogers:
