interface RS-232 GSM module
Hello Friends
I’ve bought this Siemens TC-35i GSM module:
However I don’t know how to wire it to the Arduino, I didn’t find anything on the Playground except software related things.
Does it need any chip (usually from Maxim) for voltage translation? I read Arduino 2009 has UART TTL 5Volts serial connection on Pin 0 and 1.
Any protection diodes for ESD?
I would guess yes; the DB9 connector usually indicates true RS232 signals, and I think I can make out a Sipex IC near the DB9. Sipex manufactures MAX232 family clones, among other things.
Nope, the RS232 level translator (e.g. MAX232) usually has ESD protection as well.
-j
Thank you kg4wsv for the reply! Yes you guessed it, it's a Sipex SP3239ECA 3.0 to 5.5V RS-232 transceiver. As Arduino have already 5V signals, can I wire it directly to the GSM module? How can I wire it? I don't understand why the used a 3 to 5.5V chip when computer's RS-232 signal voltage is +12/-12V For convenience this is the DB9 RS-232 pinout
That "3V to 5.5V" is on the logic side of the chip - it can operate on 3.3V, unlike the MAX232 which needs 5V. The RS232 side is in fact +12V/-12V.
You still need an RS232 transceiver for the Arduino.
Connect TX to RX, RX to TX, and GND to GND.
-j
Great, so I just need a MAX232 and power it through the Arduino +5V, am I right? I read MAX233 is the same but without external caps. Where is the downside? I suspect it's about the cost, as the 233 costs twice the 232...
Thank you for the patience, I'm a bit more on the software side - in fact I already learned all the necessary AT commands through a GSM USB modem..
Where is the downside? I suspect it’s about the cost, as the 233 costs twice the 232…
That’s it. The 233 is a bit bigger, too, although probably not as big as a 232+5 TH caps.
-j
Thank you for the reply!
I read there are several MAX232 clones, like ones from ST and TI that can cost 10x less. Can I go away with them or better to stick to the original one?
Clones are just fine. I've used TIs, and several devices I own have the Sipex.
-j
