Hi all,
This is a simple program that I created to read an LTC1298 12 bit ADC. I am using it to read an MPX4115 pressure sensor. Here is the code:
LTC1298 - Arduino interface
Matt Sargent
October 2009
This example is essentially a port of the code that is contained in the
Peter Anderson article. I believe the code was written by Towanda Malone, Baltimore, MD in Apr, '99.
Here is a link to the article:
http://www.phanderson.com/PIC/PICC/CCS_PCM/1298.html
I updated the code to work with the Arduino. I am using the default board, so I did not make any
adjustments for the speed at which the conversions are being made. I do take 20 samples and delay 1 ms
between each and then average them. I have added an error amount that I have found is needed to get my
barometer to match the local one at the Naval Air Station.
Connections:
The LTC1298 is connected thus:
LTC1298 | Arduino Pin (not ATMEGA328)
CLK (7) | Pin 2
Din (5) | Pin 3 Note same pin as below
Dout (6) | Pin 3 Note same pin as above
!CS (5) | Pin 4
Data sheets:
http://cds.linear.com/docs/Datasheet/128698fs.pdf
References:
const int CS_PIN=4;
const int Dinout_PIN=3; //Din and Dout are both connected to pin 3...
const int CLK_PIN=2;
void setup(void)
//Set output pins to output
pinMode(CS_PIN, OUTPUT);
pinMode(CLK_PIN, OUTPUT);
//Setup this pin, though it changes from input to output and vice versa
pinMode(Dinout_PIN, OUTPUT);
// start serial port
float samples;
float analogValue;
float adjustment = 1.0;
float P; //pressure in millibars
float temp;
void loop(void) {
samples = 0.0;
for (int i = 0; i < 20; i++)
temp = ReadFromLTC1298(0x0d); //single ended Ch 0
samples = samples + temp;
delay(1);
//now average the 20 samples
analogValue = samples / 20.0;
P = analogValue * 0.272 + 105.5 + adjustment; //For 12 bit ADC
// print the result:
Serial.print("P(avg)=");
Serial.print(P);
P = P * 0.0295301; //convert to in Hg...
Serial.print("; in Hg = ");
Serial.print(P);
Serial.print(" Analog Value=");
Serial.println(analogValue);
delay(500); //wait a 1/2 second so the screen does not fly by...
int ReadFromLTC1298(int command)
int aBit;
int n;
int result = 0x0000;
//Set data pin for output so we can send the command
//make sure the chip is not selected
digitalWrite(CS_PIN, HIGH);
//Initialize the clock high
digitalWrite(CLK_PIN, HIGH);
//Select the chip (LTC1298 will reset)
digitalWrite(CS_PIN, LOW);
//write the command to the LTC1298
for (n=0; n<4; n++)
aBit = (command >> (3-n)) & 0x01;
digitalWrite(Dinout_PIN, aBit); //Most sig fig first
//Pulse in the bit...
digitalWrite(CLK_PIN, LOW);
//Change the Dinout to input for reading
pinMode(Dinout_PIN, INPUT);
//dummy clock pulse
//Read in the 12 bits of data
for (n=0; n<12; n++)
//Pulse the clock...
aBit = digitalRead(Dinout_PIN);
result = (result << 1) | aBit;
digitalWrite(CS_PIN, HIGH); //De-Selected the chip
return result;
