Interface two 23LC1024 SRAMs with Arduino Uno using SPI
Hello everyone!
First up, I am new to all this so please be gentle!
Now what gives my headaches: I am trying to interface two 23LC1024 SRAMs with an Arduino Uno. I tried daisy-chaining the two SRAMs, but only the first one seems to be written to correctly.
I tested both SRAMs on their own - so it does not seem to be a hardware problem (unless I messed up the wiring - diagram attached).
Here is the code I am using:
#include <SPI.h>
#define RDSR      5
#define WRSR      1
#define READ      3
#define WRITE     2
uint8_t cs_pin[2] = {10, 9};   //chip select pins
//Byte transfer function - read
void Spi23LC1024Read8(uint32_t address, uint8_t cs_pin) {
  uint8_t read_byte;
  digitalWrite(cs_pin, LOW);
  SPI.transfer(READ);
  SPI.transfer((uint8_t)(address >> 16));
  SPI.transfer((uint8_t)(address >> 8));
  SPI.transfer((uint8_t)address);
  read_byte = SPI.transfer(0x00);
  digitalWrite(cs_pin, HIGH);
  Serial.print("READ: address: ");
  Serial.print(address);
  Serial.print(", value: ");
  Serial.println(read_byte);
//Byte transfer function - write
void Spi23LC1024Write8(uint32_t address, uint8_t data_byte, uint8_t cs_pin) {
  SPI.transfer(WRITE);
  SPI.transfer(data_byte);
void setup(void) {
  uint32_t i;
  SPI.begin();
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
  pinMode(9, OUTPUT);
  digitalWrite(9, HIGH);
  Serial.println("For SRAM 1 (pin 10):");
  for (i = 0; i < 32; i++) {
    Spi23LC1024Write8(i, (uint8_t)i, cs_pin[0]);
    Spi23LC1024Read8(i, cs_pin[0]);
  Serial.println("For SRAM 2 (pin 9):");
    Spi23LC1024Write8(i, (uint8_t)i, cs_pin[1]);
    Spi23LC1024Read8(i, cs_pin[1]);
And the output I am getting:
For SRAM 1 (pin 10)
READ: address: 0, value: 0
READ: address: 1, value: 1
READ: address: 2, value: 2
READ: address: 3, value: 3
READ: address: 4, value: 4
READ: address: 5, value: 5
READ: address: 6, value: 6
READ: address: 7, value: 7
READ: address: 8, value: 8
READ: address: 9, value: 9
READ: address: 10, value: 10
READ: address: 11, value: 11
READ: address: 12, value: 12
READ: address: 13, value: 13
READ: address: 14, value: 14
READ: address: 15, value: 15
READ: address: 16, value: 16
READ: address: 17, value: 17
READ: address: 18, value: 18
READ: address: 19, value: 19
READ: address: 20, value: 20
READ: address: 21, value: 21
READ: address: 22, value: 22
READ: address: 23, value: 23
READ: address: 24, value: 24
READ: address: 25, value: 25
READ: address: 26, value: 26
READ: address: 27, value: 27
READ: address: 28, value: 28
READ: address: 29, value: 29
READ: address: 30, value: 30
READ: address: 31, value: 31
For SRAM 2 (pin 9)
READ: address: 0, value: 31
READ: address: 1, value: 223
READ: address: 2, value: 0
READ: address: 3, value: 215
READ: address: 4, value: 255
READ: address: 5, value: 0
READ: address: 6, value: 0
READ: address: 7, value: 255
READ: address: 8, value: 255
READ: address: 9, value: 255
READ: address: 10, value: 255
READ: address: 11, value: 0
READ: address: 12, value: 0
READ: address: 13, value: 0
READ: address: 14, value: 0
READ: address: 15, value: 251
READ: address: 16, value: 255
READ: address: 17, value: 255
READ: address: 18, value: 255
READ: address: 19, value: 255
READ: address: 20, value: 255
READ: address: 21, value: 255
READ: address: 22, value: 255
READ: address: 23, value: 0
READ: address: 24, value: 255
READ: address: 25, value: 0
READ: address: 26, value: 0
READ: address: 27, value: 0
READ: address: 28, value: 0
READ: address: 29, value: 0
READ: address: 30, value: 0
READ: address: 31, value: 255
What am I doing wrong? Any comments will be greatly appreciated (and when I say greatly, I actually mean you’ll be my hero forever!) :grinning:
P.S. Apologies if this is not the right place for this topic… wasn’t exactly sure where to post is
Lealine:
Hello everyone!
What am I doing wrong? Any comments will be greatly appreciated (and when I say greatly, I actually mean you'll be my hero forever!) :grinning:
P.S. Apologies if this is not the right place for this topic.. wasn't exactly sure where to post is
Code looks good, The only recommendation I can offer is to add a couple of bypass capacitors 0.1uf to each SRAM, between Vcc and Gnd.
Also, Breadboards are notorious for bad connections. Try using a different section of your breadboard.
Chuck.
Thanks for your reply! I used a different section of my breadboard, I even tried a brand new one, but that didnt do the trick... BUT, I added a pull-up resistor to the first SRAM and... IT WORKS!!!!! I tried adding a pull up resistor to both SRAMs, but that doesnt change anything.. only adding it to the first one does the trick..
So basically, it works, but I don't know why.. Any thoughts?
Lealine:
pull up were?
Chuck.
