I need my Arduino to see when a motor turns on in a pinball machine (the "Time Machine" motor). The motor is 24V AC and is activated from a 20V DC signal to a relay board (+20V is constant, switched with ground). Right now I have a current switch on the 24V motor input. While this works, the switch is expensive and bulky, looking for a lower cost solution.
My next idea is to use a solid state relay triggered with 24V AC (~ $15). The relay board has a pigtail connector where I can tap into the wires (I do not want to cut/splice wires on the pinball machine). The pins and Molex housings to make the tap will probably be ~ $15 so this solution is ~$30. Any ideas for a cheaper way to read when the motor is on?
24v ac relay on the motor but.......if it doesn't turn you're out of luck.
A small magnet on the motor shaft with a reed switch will give a pulse to Arduino and verify it is actually turning.
You could connect that "switching" ground to arduino input. Put diode in series to protect arduino in case there are pullups on that line. Optocoupler is a good option as well.
Or ACS712-module...
