Hi.
I have a Arduino Pro 3.3V version. I was wondering how I would be able to interface this with standard 5V servos? Can this be done?
Cheers
Mitch
Hi.
Cheers
Mitch
You will have to supply +5vdc from a different supply source to the servo's power lead and make sure to connect the ground of the external supply to the boards ground pin.
Lefty
Power wasn't a huge issue I suppose, but can I use a 3.3V Arduino to actually communicate with the servo or do I need some kind of logic converter?
The 3.3 volt logic high should work OK for the servo's input control signal. Breadboard it first to determine for sure as there may be a pick servo or two out there.
Lefty
