Thank you. I checked it a few times over and then switched to a different set of pins with the same results. It is strange. Do you think it has something to do with timing? ... maybe the wiring board's timing is different from the Arduino.
Phil
Phil
Maybe the pin mapping is different between wiring an arduino. remember the pin #'s in the arduino world typically refer to the arduino board's pin numbers, not the microcontroller pin numbers.
Arduino was obviously inspired/based on/an offshoot of (not sure of the technical term, don't want to offend the tinket.it guys) the wiring board, so maybe the numbers match, I'm not sure.
That's a good possibility, but I don't think I would have seen anything on the serial monitor.
Phil
Timing shouldn't be a problem, the code is all bit-banged. It's very timing insensitive, and doesn't rely on any chip-specific features.
I'm pretty sure it is a pin mapping problem. I just checked out the schematic at:
It looks like Port 3 is where I need to be wiring the ADC to ... I was originally trying to use Port 1 on the Wiring Mini
Wiring Mini Board pins MCP3208 ADC Pins
24 -----> CS Chip Select Pin 10
25 -----> CLC Clock Pin 13
26 -----> Din MOSI Pin 11
27 -----> Dout MISO Pin 12
Looks like this should work. I'm out on the road with my job right now. I should be able to check this on Monday.
Phil
I've been messing around with it for the last couple hours on the correct pins ... still the same results. I have no idea what may be the problem.
Phil
I'm back to just using this on Arduino.
I'm trying to use the AGND pin. I tried putting about 2V on it, but it just shunts down to millivolts ... since it is an analog ground. Is AGND really meant for setting a lower limit? The spec sheet doesn't really mention too much about it.
Phil
I figured it out. I had to use a separate power source for the analog end of things. I connected the pot wiper (from analog source) to AGND pin.
In the end it brings the resolution down to only 11 bits instead of 12. I have my Vref set to 4.77V (from digital source) and AGND of 2.25V .... my ADC range is from 0 to 2047. Is there any way to make this range from 0 to 4095 ?
P.S. I didn't connect the Analog ground to the digital ground.
Phil
Hi halabut,
I am a newbie with arduino. I'm currently trying to implement ADC MCP3204. I tried to use your code and connect similarly but my adcvalue keeps reading either zero or 4095 (5V). I suspect it's the timing but the datasheet for both 3204 and 3208 have the exact same timing. Please help, thanks!
That's strange, especially given that they're the same datasheet. Looking at the code it should work fine (for the first four channels only obviously)
All I can advise is checking your connections against the datasheet, the pins are in the same order (except dgnd on the left). Many of my frustrating 'broken' circuits have been me forgetting to connect ground, so check everything twice. Other than that it might (and this is unlikely) be a dud chip.
Alec
Hi halabut,
Thank you very much for replying so early. I finally got it working with a little modification on your code. Instead of:
int adcvalue = 0;
byte commandbits = B11000000; //command bits - start, mode, chn (3), dont care (3)
//allow channel selection
commandbits|=((channel-1)<<3);
digitalWrite(SELPIN,LOW); //Select adc
// setup bits to be written
for (int i=7; i>=3; i--){
digitalWrite(DATAOUT,commandbits&1<<i);
//cycle clock
digitalWrite(SPICLOCK,HIGH);
digitalWrite(SPICLOCK,LOW);
I changed it to:
int adcvalue = 0;
byte commandbits = B110000 + channel; //command bits - start, mode, chn (3)
for (int i=4; i>=0; i--)
if ((commmandbits>>i)%2 == 1)
{ digitalWrite(DATAOUT,HIGH); }
{ digitalWrite(DATAOUT, LOW); }
//cycle clock
I'm not sure why u had (channel-1) in your code but i got it working in the end using most of your code. Thank you very much. ![]()
I found it was very nice to manually adjust the clock pin HIGH and LOW rather than having it running automatically in the background. Thus, timing is up to us to control rather than the arduino controller.
Part of my project is to also have a DAC12bit (TLV5616). I tried similar thing with your code but it does not work. I always get zero. Do you have any idea, please help me out. I already tried using the SPI library but didn't work. Thanks in advance.
Here's my code so far for the DAC:
void writeDacSPI(byte voltValue)
byte commandbits = B11111111;
displayOnLCD(0,1, commandbits);
digitalWrite(dacFSPin, LOW); // turn on DAC
for (int i = 7; i >= 0; i--)
if ((commandbits>>i)%2 == 1)
{ digitalWrite(dataOutSPI, HIGH);}
{ digitalWrite(dataOutSPI, LOW); }
digitalWrite(clockSPI,HIGH);
digitalWrite(clockSPI,LOW);
if ((voltValue>>i)%2 == 1)
digitalWrite(dacFSPin,HIGH); // turn off DAC device
The chan-1 makes it 1 based, rather than 0 based.
I think I know why you get 0 from the DAC: setting bit 13 to 1 will power down the chip! The data bits go x S P x d d d d d d d d d d d d
x = don't care
S = speed (1=fast)
P = power (1=off)
d = data bits (12)
Alec
Hi halabut,
U r right. I misunderstoood the spec sheet when it says "in power down mode, all amplifier are disabled". Thanks a lot ![]()
This also works with the 13-bit MCP3302.
Change
//read bits from adc
for (int [glow]i=11[/glow]; i>=0; i--){
adcvalue+=digitalRead(DATAIN)<<i;
//cycle clock
digitalWrite(SELPIN, HIGH); //turn off device
return adcvalue;
to:
for (int [glow]i=12[/glow]; i>=0; i--){
//cycle clock
return adcvalue;
This allows reading in the extra bit that the 3302 provides. Thanks for the code, it works great for my application ![]()
hello - maybe this thread is dead, but I just wanted to thank halabut for posting that code, works like a charm!
for those that can't get it to work, check your wiring - i had my Vref set to ground by mistake the first time and kept getting 4095
