interfacing a 3.3V sensor
I have been facing issues trying to get the right data with the 3.3V sensor.
the values obtained are different from the values when i use a 5V sensor, where i am getting the desired result.
should a level converter be used and how?
Using a current sensor with high sensitivity.
thank you
It sounds like you are reading an analog input and scaling it incorrectly in one case.
Post the required details, after reading "How to use this forum".
