Hello everybody, i bought a GPRS MODEM from the DealExtreme website.
I would like to interface it with the Arduino DuemilaNove using this schematics:
http://finch.am/projects/arduinogsm/
I connected the wires in the correct way and i used the code you can find on the page above, but it doesn't works!
- I correctly soldered all the wires (checked with multimeter);
- I used the correct diode and the correct resistor;
- When i upload the program and open the serial monitor, i can't see anything, even if with this program i should read "Ok" from the modem;
- I measured the output voltage of the modem: 3,4 volts, maybe is too low for the Arduino digital input?
.....who can help me? Maybe i have to amplify the output modem signal? If yes, in wich way? With an OpAmp?
Thanks for reading ![]()
