Interfacing a LOUD buzzer with arduino nano
I have to use a loud buzzer for my project. Please suggest me a really loud buzzer so that i can use it. I would also like to know how do we interface that buzzer with arduino? simply connect its ground with arduino's ground and the positive terminal with a digital output pin?
The Arduino I/O pins put-out 5V at 40mA or less. If you need more than that, you'll need something like a [u]MOSFET[/u]. If your buzzer requires a different voltage from the Arduino, you may need a separate power supply.
If your buzzer has it's own built-in sound generator, you can simply switch-on & off the output pin. If the Arduino needs to generate the sound, you'll have to send a square wave to the output. Either way, the MOSFET will work.
Yes, the way to get loud out of a piezo is to increase the voltage. I've done
experiments on this. Using the same piezo:
3.3V --> usable as an indicator.
5V --> same, but somewhat louder.
9V-12V --> chase you out of the room.
The other thing is, a piezo is MUCH MUCH louder when driven at its resonant
frequency than at other frequencies.
oric_dan:
How does one determine the resonant frequency? They aren't marked with it.
A detailed data sheet might have it, otherwise hook it to an audio sig-gen and play around.
Yes! 9V - 12V will be just perfect then! Thanks
I figured it out how to make a Piezo loud after way too long. You add an Auto-transformer to the circuit that you can get at the dollar store. I made an instructable on it here:
