I'm hoping to acquire data from a self-contained (no output ports) Magnetic Linear Slide. Attached is a picture of the electronics--the batteries are contained in the LCD unit and the LCD unit is attached to the magnetic slide via micro B USB to micro B USB connection. The magnetic slide itself seems to require power from the LCD unit to operate (it's not a just a mechanical potentiometer).
Any guidance anyone could provide would be greatly appreciated!
The magnetic slider has some 40 or 50 magnets (when i look at your fotos).
A magnetic signal is picked up with a reed relay or a hall sensor.
If you have a look at the electronics in your device,
you might be able to find out what it is and pick up the signals at the sensor.
If it is a reed relay it is very easy,
if it is a hall sensor you have to google for the data sheet to find out about the connections.
The Arduino analog inputs have a high-ohm input so you do not have to care about a voltage loss.
You might need a resistor divider in this case if the input is higher than 5 volts.
(this is probably not the case as the device is powered via an usb cable).
if the speed of your device is controlled by the black box it will be hard to replace its electronics
with a simple sensor.
"if the speed of your device is controlled by the black box it will be hard to replace its electronics
with a simple sensor."
The slide is manually actuated--there's no actual motor or anything moving the slide. It's meant to be attached to a mill or something to measure linear motion.
"A magnetic signal is picked up with a reed relay or a hall sensor.
you might be able to find out what it is and pick up the signals at the sensor."
This is a good idea! I'll take a look and see if I can try to deduce the sensor and plug into the output. Thanks!
Hmm..so this is what the magnetic slide sensor part looks like. I can't tell what sort of sensor it's using, or what lines on the PCB I should tap into to get a signal.
