Hello.
I have a problem interfacing an accelerometer and Processing, using some code i found on the net...
I have no clue how to use Processing - other than the IDE is very similar to Arduino IDE. I would like to show a working accelerometer to a class, i'm attending to (and to demonstrate Arduino's to the class - so that others maybe get some interest in these small marvels :)) - and i have found some code on the net, but does'nt have a clue how to get Processing to work.
It is taken from here... Management System and the code is here...
Arduino code:
#define X_AXIS 0
#define Y_AXIS 1
#define Z_AXIS 2
int x = analogRead(X_AXIS);
int y = analogRead(Y_AXIS);
int z = analogRead(Z_AXIS);
Serial.print(x);
Serial.print('|');
Serial.print(y);
Serial.print(':');
Serial.println(z);
And the Processing code:
import processing.serial.*;
import processing.opengl.*;
Serial myPort;
int baudRate = 9600;
int lf = 10;
PFont font;
int[] xAxis;
int[] yAxis;
int[] zAxis;
int currentX = 0;
int currentY = 0;
int currentZ = 0;
//these value were determined by taking readings from a resting position
int oneGSensorValue = 400;
float oneGMillivolt = oneGSensorValue * 4.9;
int totalReadings = 400;
int readingPos = 0; // the reading position in the array
void setup(){
smooth();
size(600, 300, OPENGL);
font = createFont(PFont.list()[270], 24);
smallFont();
xAxis = new int[totalReadings];
yAxis = new int[totalReadings];
zAxis = new int[totalReadings];
for (int i=0; i < totalReadings; i++){
xAxis[i] = oneGSensorValue;
yAxis[i] = oneGSensorValue;
zAxis[i] = oneGSensorValue;
myPort = new Serial(this, Serial.list()[0], baudRate);
myPort.bufferUntil(lf);
noLoop();
void serialEvent(Serial p){
String inString;
try{
inString = (myPort.readString());
currentX = xValue(inString);
currentY = yValue(inString);
currentZ = zValue(inString);
xAxis = insertValueIntoArray(xAxis, currentX, readingPos, totalReadings);
yAxis = insertValueIntoArray(yAxis, currentY, readingPos, totalReadings);
zAxis = insertValueIntoArray(zAxis, currentZ, readingPos, totalReadings);
readingPos = readingPos + 1; // increment the array position
}catch(Exception e){
println(e);
redraw();
void draw()
background(#FEFFFC);
drawGraph(xAxis, 100, color(#519050), "X - Axis");
drawGraph(yAxis, 200, color(#708CDE), "Y - Axis");
drawGraph(zAxis, 300, color(#D38031), "Z - Axis");
draw3d(currentX, currentY, currentZ);
void drawGraph(int[] arrToDraw, int yPos, color graphColor, String name){
int arrLength = arrToDraw.length;
stroke(graphColor);
for (int x=0; x<arrLength - 1; x++) {
float normalizedLine = norm(arrToDraw[x], 0.0, 700.0);
float lineHeight = map(normalizedLine, 0.0, 1.0, 0.00, 85.0);
line(x, yPos, x, yPos - int(lineHeight));
pushStyle();
smallFont();
stroke(#FFFFFF);
fill(#FFFFFF);
String gString = nfc(gFromSensorValue(arrToDraw[arrLength - 2]), 2);
text(name + " : " + gString + " Gs", 10, yPos - 10);
popStyle();
void draw3d(int currentX, int currentY, int currentZ){
float normalizedX = norm(currentX, 0.0, 700.0);
float normalizedY = norm(currentY, 0.0, 700.0);
float normalizedZ = norm(currentZ, 0.0, 700.0);
float finalZ = map(normalizedZ, 0.0, 1.0, 300.00, 0.0);
float finalY = map(normalizedY, 0.0, 1.0, -3.5, 3.5);
float finalX = map(normalizedX, 0.0, 1.0, -3.5, 3.5);
pushMatrix();
ambientLight(102, 102, 102);
lightSpecular(204, 204, 204);
directionalLight(102, 102, 102, -1, -1, -1);
shininess(1.0);
translate(500, finalZ);
rotateY(finalY + 1.0);
rotateZ(finalX);
fill(#E2E8D5);
noStroke();
fill(#B76F6F);
float heightWidth = finalX * 1.8;
box(65, 65, 50);
popMatrix();
int xValue(String inString){
int pipeIndex = inString.indexOf('|');
return int(inString.substring(0,pipeIndex));
int yValue(String inString){
int colonIndex = inString.indexOf(':');
return int(inString.substring(pipeIndex+1, colonIndex));
int zValue(String inString){
return int(inString.substring(colonIndex + 1, inString.length() - 2));
This little method creates a running tally of all the incoming sensor readings
and then, when it reaches the end of the array, it pops the first one of the beginning
and inserts a new value in at the end...thus keeping a running tally of the last 400
readings (it can be for any length array, that's just what it's set to for this project).
This works a lot like an RRD graph where my inspiration came from.
int[] insertValueIntoArray(int[] targetArray, int val, int pos, int maxLength){
if(pos > (maxLength-1)){
// if the pos == maxSize, shift the array to retain the original value
int[] returnArray = subset(targetArray, 1, maxLength-1);
returnArray = expand(returnArray, maxLength);
returnArray[maxLength-2] = val;
return returnArray;
}else{
targetArray[pos] = val;
return targetArray;
This conversion will vary from project to project
and if you're project is relying on battery power
the reading may need to be adjusted to give you true
one G as your battery power decreases. All of this is due to
the output of the X,Y, and Z sensors and their coorelation to the incoming voltage at VCC
Check out the specs for the ADXL335 (part of the break out board from Sparkfun.com) here: http://www.analog.com/en/sensors/inertial-sensors/adxl335/products/product.html
float gFromSensorValue(int sensorValue){
//convert analog value into millivolts
float mvValue = sensorValue * 4.9;
return mvValue/oneGMillivolt;
void smallFont(){ textFont(font, 24); }
void mediumFont(){ textFont(font, 30); }
void largeFont(){ textFont(font, 40); }
But i can't seem to get the Processing code to work. The Arduino code is very simple, and it works when i try it in serial monitor. What am i missing here??? I can't seem to get it to work, as if there were no connection between the Arduino and Processing... ![]()
If only i could get it to work, then i could start adjusting the details in the program later....
