/* Arduino robot car and claw bot control using Hc-08 bluetooth low energy module and arduino Nano 33 IOT
* == SLAVE DEVICE - ARDUINO ROBOT CAR WITH MEGA 2560 BOARD ==
* This program sets the hc-08 module connected to serial pins (0,1) or rx, tx on the arduino mega board to a name that the Nano 33 IOT central/master controller searches for and connects to.
* Then reads / receives the (Sent/advertiesed) characteristics from the joystick and IMU readings on the Nano 33 IOT
* and operates the robot car based on received data.
* by Saheed Quadri, Dec , 23 2021
#include <AccelStepper.h> //To control the three stepper motors that make up 3 axis of the robot car's arm
#include <Servo.h> // To control the servos that make up the remaining two axis, and the claw of the robot arm
#include <SPI.h> //To use the on board 128 X 32 oled display
#include <Wire.h> //To use the on board 128 X 32 oled display
#include <Adafruit_GFX.h> //To use the on board 128 X 32 oled display
#include <Adafruit_SSD1306.h> //To use the on board 128 X 32 oled display
#include <IRremote.h> // For the on board IR receiver (Not used in this sketch)
#include "BLESerial.h" // To use the hc-08 module as a BLE device and receive data sent by the nano 33 IOT central/master controller (Not Sure how to code this part or if this is the right library to do so)
BLESerial ble(0, 1); //defining the serial pins for the bluetooth serial library (Not entirely sure if it's needed)
//Declare all accesory Pins
const int PWMA = 10; // declare control pins for car motors
const int PWMB = 11;
const int DIRA = 12;
const int DIRB = 13;
// Define step constants
#define FULLSTEP 4
#define HALFSTEP 8
Servo servo1, servo2, servo3; // declare servo pins
AccelStepper stepper1(FULLSTEP, 28, 24, 26, 22); // declare stepper pins and step amount using step constants
AccelStepper stepper2(FULLSTEP, 46, 50, 48, 52);
AccelStepper stepper3(FULLSTEP, 29, 25, 27, 23);
const int Trig = 8; // declare pins for the onboard ultrasonic sensor (not used in this sketch);
const int Echo = 7;
const int BuzzerPin =4; // declare onboard buzzer pin
const int RECV_PIN = 5; // declare onboard IR Receiver pin (Not used in this sketch)
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
#define OLED_RESET -1 // Reset pin # (sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET); //For the onboard 128 X 32 OLED display
IRrecv irrecv(RECV_PIN);// for the onboard IR Receiver
decode_results results;
void setupRobotCar() // Void method for robot car and other accesory setup (To keep the code clean and understandable)
// All pins should be setup as outputs:
pinMode(PWMA, OUTPUT);
pinMode(PWMB, OUTPUT);
pinMode(DIRA, OUTPUT);
pinMode(DIRB, OUTPUT);
pinMode(BuzzerPin, OUTPUT);
// Initialize all motor pins as low (otherwise the car moves on it's own and never fully stops):
digitalWrite(PWMA, LOW);
digitalWrite(PWMB, LOW);
digitalWrite(DIRA, LOW);
digitalWrite(DIRB, LOW);
//Attach servo to pins
servo1.attach(2);
servo2.attach(9);
servo3.attach(6);
/*Void methods for moving the moto wheels in different directions
* Please note that this is not the final form and i wish to map the values to one of the joystick data received from the nano master controller
* Please note that the car is a four wheel drive, using one l298p hbrigde module sheild (with two motors assigned to one pair of pins)
* Therefore, PWM values can not be below about 150, as the motors would draw too much current and end up frying the arduino
* Please note that thge l298p hbridge module sheild use translates a digital LOW on the enable pins (DIRA, DIRB) as reverse, and a digital HIGH as foward
* while an analog zero (0) or digital low stops the motors
// Movement and directions
void Foward()
analogWrite(PWMA, 250);
analogWrite(PWMB, 250);
digitalWrite(DIRA, HIGH);
digitalWrite(DIRB, HIGH);
//Moving the card foward
void Left()
analogWrite(PWMA, 200);
analogWrite(PWMB, 200);
void Right()
void Back()
//To stop the motor
void Stop()
analogWrite(PWMA, 0);
analogWrite(PWMB, 0);
//Void method that currently shows an example of how the accel library is used, but would be modified to change the acceleration and move to values based on received data from the bluetooth module
void StepperControl(){
stepper1.setMaxSpeed(1000.0);
stepper1.setAcceleration(100.0);
stepper1.setSpeed(600);
stepper1.moveTo(100);
// set the same for motor 2
stepper2.setMaxSpeed(1000.0);
stepper2.setAcceleration(100.0);
stepper2.setSpeed(500);
stepper2.moveTo(100);
stepper3.setMaxSpeed(1000.0);
stepper3.setAcceleration(100.0);
stepper3.setSpeed(600);
stepper3.moveTo(100);
stepper1.run();
stepper2.run();
stepper3.run();
//My current understanding of how the BLEserial library might work, need a lot of help figuring out it it its the right library, and if yes, how to receive characteristics advertised, or datat sent by the nano 33 IOT
ble.begin();
ble.setName("SAHEED'S_ROBOT_CAR");
ble.setSerialBaud(9600); // Set the Baud rate for Hardware serial console, defaults to 9600
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally for the OLED display
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
setupRobotCar(); // Set all pins as outputs
