Hi all¡
I´m researching to use an commercial anemometer with Arduino to feed data in a website.
I found that a lot of people used the Vortex Wind sensor with results, even they post the code to use it.
http://www.inspeed.com/anemometers/Vortex_Wind_Sensor.asp
http://timeinventorskabinet.org/wiki/doku.php/windclocks/anemometer
But besides the wind speed i need to measure wind direction; so I found an anemometer with wind vane included:
http://www.peetbros.com/shop/custom.aspx?recid=14
http://www.42.co.nz/freeboard/technical/interfacing/peetbrosanemometer.html (how to wire it)
I think that the way to get the anemometer data is the same (or similar) from one anemometer to the other, but I can´t find how the wind direction data can be pulled from the sensor, on the description they say:Wind direction is determined by measuring the relative timing between pulses from the two switches. North is indicated when the two sets of pulses exactly coincide. South is indicated when pulses from one switch occur exactly midway between consecutive pulses from the other switch.
It´s possible to get this pulses info with Arduino to measure the wind direction? Any ideas or clues to be secure before I buy it?
Thank you guys¡
