Interfacing ANO encoder to DUE with I2C issues
Hello all, I am relatively new to using Arduino and I have both an UNO and a DUE. For upcoming projects, I intend to use the DUE as a controller to connect to multiple devices. However, I am currently struggling to interface or communicate with my recently purchased Adafruit ANO rotary encoder and its respective I2C breakout board. Adafruit ANO Rotary Encoder to I2C Adapter
When I connect the encoder to my Arduino Due, upload the code through the USB port, and use the sample code provided on the documentation page, the LED's on the device work as intended but nothing is displayed through the serial monitor.
 * This example shows how to read from a seesaw encoder module.
 * The available encoder API is:
 *      int32_t getEncoderPosition();
        int32_t getEncoderDelta();
        void enableEncoderInterrupt();
        void disableEncoderInterrupt();
#include "Adafruit_seesaw.h"
#define SS_SWITCH_SELECT 1
#define SS_SWITCH_UP     2
#define SS_SWITCH_LEFT   3
#define SS_SWITCH_DOWN   4
#define SS_SWITCH_RIGHT  5
#define SEESAW_ADDR      0x49
Adafruit_seesaw ss;
int32_t encoder_position;
  while (!Serial) delay(10);
  Serial.println("Looking for seesaw!");
  if (! ss.begin(SEESAW_ADDR)) {
    Serial.println("Couldn't find seesaw on default address");
    while(1) delay(10);
  Serial.println("seesaw started");
  uint32_t version = ((ss.getVersion() >> 16) & 0xFFFF);
  if (version  != 5740){
    Serial.print("Wrong firmware loaded? ");
    Serial.println(version);
    while(1) delay(10);
  Serial.println("Found Product 5740");
  ss.pinMode(SS_SWITCH_UP, INPUT_PULLUP);
  ss.pinMode(SS_SWITCH_DOWN, INPUT_PULLUP);
  ss.pinMode(SS_SWITCH_LEFT, INPUT_PULLUP);
  ss.pinMode(SS_SWITCH_RIGHT, INPUT_PULLUP);
  ss.pinMode(SS_SWITCH_SELECT, INPUT_PULLUP);
  // get starting position
  encoder_position = ss.getEncoderPosition();
  Serial.println("Turning on interrupts");
  ss.enableEncoderInterrupt();
  ss.setGPIOInterrupts((uint32_t)1 << SS_SWITCH_UP, 1);
  if (! ss.digitalRead(SS_SWITCH_UP)) {
    Serial.println("UP pressed!");
  if (! ss.digitalRead(SS_SWITCH_DOWN)) {
    Serial.println("DOWN pressed!");
  if (! ss.digitalRead(SS_SWITCH_SELECT)) {
    Serial.println("SELECT pressed!");
  if (! ss.digitalRead(SS_SWITCH_LEFT)) {
    Serial.println("LEFT pressed!");
  if (! ss.digitalRead(SS_SWITCH_RIGHT)) {
    Serial.println("RIGHT pressed!");
  int32_t new_position = ss.getEncoderPosition();
  // did we move around?
  if (encoder_position != new_position) {
    Serial.println(new_position);         // display new position
    encoder_position = new_position;      // and save for next round
  // don't overwhelm serial port
  delay(10);
I've tried using Adafruit's script to locate the I2C device, but when I check the serial monitor, I don't see any output, not even a "scanning" message.
// SPDX-FileCopyrightText: 2023 Carter Nelson for Adafruit Industries
// SPDX-License-Identifier: MIT
// i2c_scanner
// Modified from https://playground.arduino.cc/Main/I2cScanner/
#include <Wire.h>
// Set I2C bus to use: Wire, Wire1, etc.
#define WIRE Wire
  WIRE.begin();
  while (!Serial)
     delay(10);
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    WIRE.beginTransmission(address);
    error = WIRE.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
I've uploaded the code I'm using and the circuit diagram is the same as in the Adafruit link, but using a DUE instead of an UNO. I've tried changing the connected pins from SDA and SCL to SDA1 and SCL1 and also switching the VIN from 5V to 3V3, but still nothing changes. I'm not sure if it's an issue with my DUE specifically. I tested the code with my UNO and everything works as intended, so I'm really not sure where to go from here. Any help would be greatly appreciated. Thank you!
The I2C bus uses different pins. Search for SCL and SDA on your board pin mapping.
Oops, it seems I made a typo. What I meant to say was
When I connect the encoder to my Arduino Due, upload the code through the USB port, and use the sample code provided on the documentation page...
If the Due and the sensor have different operating voltage then you should use an I2C level shifter. And don't forget pullup resistors.
The Adafruit website says,
Power with 3 to 5V DC, and then use 3 or 5V logic I2C data.
I was under the impression that the device could operate with the DUE's 3V3 logic and does not need a level shifter to operate. Is this correct? Or because the DUE is 3V3 Logic and not 3V Logic exactly I would need a level shifter.
