Interfacing Arduino Due with a D1 mini wemos
Hi all,
I'm working on a data collection system which would send data to a remote server.
because of huge volume of code, I have to use Due version of Arduino. And because of network interface shortage, I have to use Wifi for communication.
But how can I use wemos and communicate with it in Due coding?
I found in the web that I can use Due TX and RX of serial interface and connect it to wemos, but i did it and no response i got from wemos, let alone the data communication!
My simple code is this:
#include <Adafruit_ESP8266.h>
#define ESP_RST         4
  Serial.begin(57600);  while (!Serial); Serial.println("Start...");
  Serial1.begin(9600); // Soft serial connection to ESP8266
  Adafruit_ESP8266 wifi(&Serial1, &Serial , ESP_RST);
  wifi.setBootMarker(F("Version:0.9.2.4]\r\n\r\nready"));
  Serial.println(F("Adafruit ESP8266 Demo"));
  Serial.print(F("Hard reset..."));
  if(!wifi.hardReset()) {
    Serial.println(F("no response from module."));
    for(;;);
  Serial.println(F("OK."));
It sends something to serial forever and none of "no response from module" nor "OK" is shown!
Flash memory of Due: 512KB
Flash memory of D1 mini: 4,096KB
Why do you need the Due?
Very good hint!
I will check my code and specially needed RAM, I guess i can use wemos instead of Due. Only one issue I have to check is necessary pins for sensors.
However, if I face hardware pin shortage on wemos, and I get forced to use Due, is there any way to connect wemos to Due for network communication?
Arduino Due: 96KB RAM
D1 mini: 160KB RAM
This is not truly a fair way to compare the RAM of both boards. The D1 mini does not truly have 160KB available for use by your sketch.
But for a data collection system, either board will have more than sufficient RAM.
Correct. Clearly, D1 mini has only a few pins compared to Due. But it is easier to add more pins than it is to add more RAM or Flash, or to add WiFi capability. Please post a list of the pin requirements for your data collection system and the forum can suggest the best and easiest ways to achieve this.
There are many ways for doing that. But take note, that in any case you will need to write a custom code for both boards to make them able to communicate each other.
In the thread above you are shown a single code. For which board it is? Whats about the code for another arduino?
https://github.com/JAndrassy/WiFiEspAT#getting-started
