Interfacing Arduino Mega and LTC1325
Hi All,
Trying to get LTC1325 Battery Management chip interfaced with Arduino as a project. I need to send command word of 22 bits to LTC via SPI bus. Little over my head as I am not a great programmer so trying to learn in process. I would appreciate some help with this part. So far my code seems to do something from what I see on Oscope but not sure it is actually doing what I want. Once the command word is sent I should receive 8 bits to confirm all is good. Somehow would be best if serial.print was was used to output what I send and receive from LTC1325. Attached is LTC1325 doc.
#include <SPI.h>
  // Enable SPI for LTC1325
  digitalWrite(SS, HIGH);  // ensure SS stays high for now
  // Put SCK, MOSI, SS pins into output mode
  // also put SCK, MOSI into LOW state, and SS into HIGH state.
  // Then put SPI hardware into Master mode and turn SPI on
  SPI.begin();
  // Slow down the master a bit
  //SPI.setClockDivider(SPI_CLOCK_DIV64);
  const int CS_Pin = 7;
  SPI.beginTransaction(SPISettings(250000, MSBFIRST, SPI_MODE0));
  pinMode(CS_Pin, OUTPUT); // The CS_Pin should remain in a high impedance state (INPUT) when it is not in use.
  digitalWrite(CS_Pin, LOW); // Activate the CS line (CS is active LOW)
  SPI.transfer(0b00000010); // Send First byte
  SPI.transfer(0b00100100); // Send Second byte
  SPI.transfer(0b00000000); // Send Third byte
  SPI.transfer(0b00000000); // Send Forth byte
  SPI.transfer(0b00000000); // Send Fifth byte
  SPI.transfer(0b00000000); // Send Sixte byte
  pinMode(CS_Pin, INPUT); // Set CS_Pin to high impedance to allow pull-up to reset CS to inactive.
  digitalWrite(CS_Pin, HIGH); // Enable internal pull-up
  //Loop Read from LTC1325
  SPI.transfer(0b00000000); // Just send 0's
Thank You
Luca
lt1325.pdf (335 KB)
Hello Lucatz,
I cannot comment on your code as I am not familiar enough with the SPI libaray.
However:
  • pinMode commands need to be issued before digitalWrite commands as you first define an IO pin as output and then set its appropriate value.
  • Typically you would send your command (cyclically) to your device and then wait a bit for the data to leave the Arduino (delay instruction) and then read the result. This happens in the loop() function as the loop function is executed cyclically.
  • If you want to read the data, you can issue a loop after sending the command to your device. In this loop you can use small delays() and check after each small delay wether you have received an answer or not.
  • Do you see your device responding on your scope ?
Best Regards,
Johi
www.SylvesterSolutions.com [Realtime access to your Arduino variables]
Hi JOHI,
I have adjusted my sketch. I do see something on the scope but best would be to send out serial.println to see what it is sending or if I had a logic analyzer. so far all I see is a single 0 should be 8bits...I will also try with delay(10) and see if it works
Thanks
Luca
#include <SPI.h>
  //digitalWrite(SS, HIGH);  // ensure SS stays high for now
  SPI.begin();
  //const int CS_Pin = 7;
  //SPI.beginTransaction(SPISettings(50000, MSBFIRST, SPI_MODE0));
  //pinMode(CS_Pin, OUTPUT); // The CS_Pin should remain in a high impedance state (INPUT) when it is not in use.
  //digitalWrite(CS_Pin, LOW); // Activate the CS line (CS is active LOW)
  //SPI.transfer(0b00000010); // Send First byte
  //SPI.transfer(0b00100100); // Send Second byte
  //SPI.transfer(0b00000000); // Send Third byte
  //SPI.transfer(0b00000000); // Send Forth byte
  //val1 = SPI.transfer(0x00); // get RXbyte4 result and place in val 1
  //val2 = SPI.transfer(0x00); // get RXbyte5 result and place in val 2
  //SPI.transfer(0b00000000); // Send Fifth byte
  //SPI.transfer(0b00000000); // Send Sixte byte
  //val3 = SPI.transfer(0x00); // get RXbyte6 result and place in val 3
  //pinMode(CS_Pin, INPUT); // Set CS_Pin to high impedance to allow pull-up to reset CS to inactive.
  //digitalWrite(CS_Pin, HIGH); // Enable internal pull-up
  //Set Variables
  int incomingByte1;
  int incomingByte2;
  int incomingByte3;
  int incomingByte4;
  int incomingByte5;
  int incomingByte6;
  SPI.beginTransaction(SPISettings(125000, MSBFIRST, SPI_MODE1));
  //Send 6 Bytes
  incomingByte1 = SPI.transfer(0x00); // get RXbyte1 result and place in incomingByte 1
  incomingByte2 = SPI.transfer(0x00); // get RXbyte2 result and place in incomingByte 2
  incomingByte3 = SPI.transfer(0x00); // get RXbyte3 result and place in incomingByte 3
  incomingByte4 = SPI.transfer(0x00); // get RXbyte4 result and place in incomingByte 4
  incomingByte5 = SPI.transfer(0x00); // get RXbyte5 result and place in incomingByte 5
  incomingByte6 = SPI.transfer(0x00); // get RXbyte6 result and place in incomingByte 6
  //Set SerialPrint 6 Bytes
  Serial.println(incomingByte1);
  Serial.println(incomingByte2);
  Serial.println(incomingByte3);
  Serial.println(incomingByte4);
  Serial.println(incomingByte5);
  Serial.println(incomingByte6);
  //delay(1); // keep from flooding the PC screeen
Would anyone know if I would see 8 Bits instead of a single 0. Wondering if its a problem with my code or the Arduino cant parse it correctly. I think logic analyzer would help. I noticed on the scope an output which looks like logic signals. The pk-pk voltage is about 500mv, does the Arduino mega require voltage ie. 5 Volts?
Thanks
Luca
