hello,
im trying to mimic the schematic of the teensy sd adaptor
https://www.pjrc.com/teensy/sd_adaptor.html
i made some home made pcbs, purchased components and assembled them, but something is very wrong. It seems i actually blew a few bare bones arduinos (atmega32u4) with the setup. if i hook it up to a real arduino, it does not blow the board however the sd card fails to initialize. i believe the bare bones arduino is set up correct. i can upload and run any code as many times. but as soon as i connect it to my sd setup the chip stops responding and reset button is always high (sometimes after a few attempts though?) would also like to know if anyone has any way to rescue or reset these chips
parts used :
3.3v regulator: http://www.newark.com/webapp/wcs/sto...&storeId=10194
2x 1uf capacitors
sd card housing
logic convertor (same used on teensy sd adaptor) : http://www.farnell.com/datasheets/1885862.pdf
to explain the connections:
5v on arduino -> 1uf CAP (connected to GND) -> Vin on 3.3v regulator
GND on arduino -> 1uf CAP (connected to GND) -> GND tab on regulator
-all OE pins on logic convertor(LC) to GND (i feel this is where a problem could be. i see this is how it is in the schematic though)
- MOSI arduino -> input LC1
- output LC1 -> DI sd
- pin 10 arduino -> input LC2
- ouput LC2 -> CS sd
- SCK arduino -> input LC3
- output LC3 -> SCK sd
- MISO arduino -> DO sd
- tried connecting the remaining LC input 4 to output 4, but i did not do OE also as shown in schematic as i didnt notice until after the board,could this be the issue? it also does not work when those 2 pins are not connected
i have some difference in pinouts for the LC, but i dont think that should make a difference?
Also the schematic shows a pullup resistor for MISO. I've read that arduino can read the SD's DO without a pullup, but i also have tried with a 10k pullup resistor.
Also have tried using INPUT_PULLUP to enable the atmegas built in pullup resistors, but no luck
thanks in advanced!
