I am running a program that uses both arduino +processing together. Processing creates a GUI with two buttons called F and L. Whenever either button is pressed, it should write either a “F” or “L” string to the port depending on the button pressed.
//processing code
if(mousePressed) {
if(button1.pressed()) {
port.write(‘F’);
else if(button2.pressed()) {
count=0;//reset count for user input’s sake
port.write(‘L’);
Simultaneously, arduino shd be in the background listening to the port, if a “F” is called, the ensuing code should be executed. This code basically reads an RFID tag
if (Serial.available()){ //If data is available to read,
val = Serial.read(); //read it and store it as val
switch(val){
case ‘F’:
if((val = RFID.read()) == 10)
{ // check for header
bytesread = 0;
//Serial.println("byte read: "+bytesread);
while(bytesread<10)
{ // read 10 digit code
val = RFID.read();
if((val == 10)||(val == 13))
{ // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
//Serial.println(“three”);
However, if ‘L’ is received, the ensuing code should be excecuted:
case 'L: Serial.println(“L”); //just to be simplistic
The problem I’m having is that: If I press the F button first, and then press the ‘L’ button, the F button is gonna keep looping for like 3 times before it executes the ‘L’ case. So, I think there’s a lag somewhere. How can I overcome this lag so that immediately I press the L button, the L case should be executed
