Hi there,
I am a C/C++ , Java , .Net desktop app developer and I am new to arduino and please excuse me if this question sounds stupid.
What my current understanding of arduino is that we can write C/C++ program in arduino IDE and push them to the arduino rom and then the arduino micro-controller runs it and controls the attached hardware to the pins and we are limited by microcontroller''s computing power.
My situation is this. I am interested in using different sensors that are available for arduino and attach them to PC/Laptop. and have my program running on PC itself which communicates with sensors. My setup should not be bound by microcontroller's processing and memory limiations like CPU /RAW because I want programs to run on PC as they'd be doing data/cpu intensive tasks..
So in this situation, do I still need to attach arduino board to my PC ? or is there a way to connect sensor's though some bridge to my PC ?
Yes you can use Arduino as the bridge between the PC and the sensors. There are other bridges also; but you can definetlely use Arduino for that purpose exactly the way you are describing.
I have a little interface using C+ on PC, it may help someone.
If you want I could help to use it. There is 3 dialog box (dimmer,relays and sensor), a login box and a COM config box.
I could modify actual serial transmited data for your aplication as you need.
Please ask me.
Thank you.
you can build GUIs in C++, C#, VB, etc with Visual Studio Express using the serialPort component to communicate with an Arduino.
an alternative is Java Swing or JavaFX using the JSerialComm to communicate with the arduino
