I am trying to send some data between an Arduino UNO (master) and an mBed LPC1768 microcontroller board (slave). To test that this will work I have written a simple Arduino sketch that sends 255 bytes (just ints, 1-255), waits for one second, repeats forever. The program on my mBed simply prints the recieved values to the serial port which I'm viewing with putty, and also increments a counter every time a byte is recieved. This way the mBed slave knows if it's recieved the correct byte. But my problem is that it doesn't seem to work- at least not very well. usually 3 or 4 bytes are recieved before it reports a mismatch, and I have tried at every possible clock speed, even tried with a 1ms delay between each byte.
I tried this same test program with 2 mBed boards and it worked just fine- for some reason with an Arduino as the master it is unreliable. Can anybody shed any light on this?
MASTER (ARDUINO)
#include <SPI.h>
void setup (void)
digitalWrite(SS, HIGH); // ensure SS stays high for now
SPI.begin ();
SPI.setClockDivider(SPI_CLOCK_DIV32);
void loop (void)
for (int i = 1; i < 256; i++){ //send 255 bytes
digitalWrite(SS, LOW);
SPI.transfer (i);
delay (1000); // 1 second delay between the next 255 bytes
} // end of loop
SLAVE (MBED)
#include "mbed.h"
Serial pc(USBTX, USBRX);
SPISlave spi(p5, p6, p7, p8); //mosi, miso, sclk
int main() {
pc.baud(115200);
int counter = 0;
int x;
while(1) {
if(spi.receive()){
counter++;
x = spi.read();
pc.printf("%d", x);
pc.printf(" ");
if(counter != x){
pc.printf("mismatch at byte no. ");
pc.printf("%d", counter);
pc.printf(", counter is at ");
pc.printf(" and the value received is ");
pc.printf("%d\n\r", x);
if(counter == 255){
x = 0;
counter = 0;
