Is there any way to have an Arduino link up with an already completed program that I did not create (I don't know if that's the correct term I am still new to programming). For example I have a multi-meter by BK precision that allows me to control it by hooking it up to to my computer. There is a program offered by BK precision that allows me to read and log the multi-meter capacitance measurements. What I want to happen is when I press the button on the BK precision program to start reading/logging measurements I also want the Arduino to switch on because I will be hooking the Arduino up to a multiplexer allowing it to access different positions of a connector by cycling through them automatically.
Please do not cross-post. Threads merged.
ddragon1999:
That's going to be really hard to do without access to the source code for that application. Maybe you can sniff out the signal it sends to the multimeter.
...proves that B&K is willing to publish the protocol for at least one of their products. I suggest a few minutes with Google. If that effort fails the next step is to contact the vendor. If that fails it is time for reverse engineering. (From time to time I miss doing that kind of work. An odd combination of frustration, euphoria, and mania.)
A slightly different approach also might work. Instead of clicking the button in the application using a mouse, use the Arduino to click the button; you will need an Arduino that can act as a HID (e.g. Leonardo).
Note that ‘clicking the button’ can be either a command from the mouse or a command from the keyboard. E.g. a button [Start] (note the underlining of the S) can be accessed using S.
No experience with the Arduino as a HID though, so not sure how easy it is to send S.
sterretje:
With Teensy (AVR) it is trivial.
The only caveat is the high speed continuous S strokes that are sent when one forgets a time delay / interlock. :o
Sterretje you are freakn awesome! Thanks for definitely pointing me in the right direction. My bad on posting twice.
