Interfacing AT89S52 with AT24C64 EEPROM using I2C
Hi All,
I am interfacing AT89S52 with AT24C64 EEPROM using I2C protocol. My purpose is to send a value, say "1" to a memory location and readback the same value.
But the problem I am facing is that : whatever value I am sending to the memory location, while reading, I am always getting 0.
Can some one please help me to sort out this problem?
I know I am doing some mistakes in my code, but not able to solve it.
Also, I written two different Read and Write function, but I am not sure which one will work.
Following is my code:
#include <AT89X52.H>  // Header file for IO operations
#include "intrins.h"
/* AT24C64 Memory*/
#define SDA P3_7
#define SCL P3_5
#define WP  P3_4
bit ack_bit;
unsigned char output;
void I2CInit(){
        SDA = 1;
        SCL = 1;
void I2CStart(){
        SDA = 1;
		SCL = 1;
		_nop_();         //No operation
		_nop_();
		_nop_();
        SDA = 0;
		_nop_();
		_nop_();
        //SCL = 0;
void I2CRestart(){
        SCL = 0;
        SDA = 1;
        SCL = 1;
        SDA = 0;
void I2CStop(){
        SDA = 0;
		SCL = 1;
		_nop_();
		_nop_();
        SDA = 1;
		_nop_();
		_nop_();
		//SCL = 0;
void I2CAck(){
        SDA = 0;
        SCL = 1;
		_nop_();
		_nop_();
        SCL = 0;
        //SDA = 1;
void I2CNak(){
        SCL = 0;
		SDA = 1;
        SCL = 1;
        SCL = 0;
		SDA = 0;
unsigned char I2CSend1(unsigned char Data)
         unsigned char i;
         for(i=0;i<8;i++){
                SCL = 0;
                if((Data&0x80)==0)
                        SDA = 0;
                        SDA = 1;
                SCL = 1;
                Data<<=1;
         SCL = 0;
	     ack_bit = SDA;
		 SCL = 1;
		 SCL = 0;
         //SDA = 1;
		 return !ack_bit;
void I2CSend(unsigned char value)	//send byte serially
	unsigned int i;
	unsigned char send;
	send=value;
	for(i=0;i<8;i++)
		SDA=send/128;			//extracting MSB
		send=send<<1;			//shiftng left
		SCL=1;
		_nop_();
		_nop_();
		SCL=0;
   ack_bit=SDA;					//reading acknowledge
   SDA=0;
unsigned char I2CRead1()			//reading from EEPROM serially
	unsigned int i,reead;
	SDA=1;
	reead=0;
	for(i=0;i<8;i++)
		reead=reead<<1;
		SCL=1;
		_nop_();
		_nop_();
		if(SDA==1)
			reead++;
		SCL=0;
	SDA=0;
	return reead;				//Returns 8 bit data here
unsigned char I2CRead(){
        unsigned char i, Data=0;
        for(i=0;i<8;i++){
                SCL = 0;
                SCL = 1;
                if(SDA)
                        Data |=1;
                if(i<7)
						Data<<=1;
        SCL = 0;
        SDA = 1;
        return Data;
void Save()					//save in EEPROM
	I2CStart();
	I2CSend(0xA0);						//device address
	I2CAck();
	I2CSend(0x11);						//word address
	I2CAck();
	I2CSend("1");							//send data
	I2CAck();
	I2CStop();
	if(ack_bit==0)
void Read()
	I2CStart();
	I2CSend(0xA0);
	I2CAck();
	I2CSend(0x11);
	I2CAck();
	I2CStart();
	I2CSend(0xA1);					 //device address
	I2CAck();
	output=I2CRead(); //read the value
	I2CAck();
	I2CStop();
int main(void)
Save(); //first save the values in EEPROM
Read(); //Then read the values from EEPROM
