Interfacing between Programming and Arduino
I would like to know what code to write to get my Arduino sketch to 'talk' to a Programming sketch. Does someone know the principles of this communication?
Fabiao
You open a serial port on each side, and use that to communicate between the two.
Do you mean that I should open the serial monitor of the Arduino IDE and the Programming serial monitor simultaneously? This is just to clarify.
Thank you for the reply.
Fabiao
No. Processing does not have a Serial Monitor. There are examples provided with Processing that show how to communicate with the Arduino. Clearly, you have not looked at them.
