interfacing between while Statement and some arduino functions (strange thing)
hi
im trying to connect push button and Fingerprint to Arduino MEGA 2560
to do this
first push the button
second the fingerprint scanner will run to scan my fingerprint
after the fingerprint scan my finger it will pass the code and run function to receive string from serial port from arduino
between these step i make checkpoint to find and detect any error
when the arduino run it will print "Please Push button"
after i push the button the fingerprint scanner will run to scan my finger
after that arduion will print "Fingerprint Work Fine"
and the do serial receiving function
but thus never happen
and when i compile that after push the button fingerprint just pulse red light and never run again
if i edit the code and make this like commend "in the receiving from serial"
the code will work and run fine and the fingerprint scanner will run and scan my finger
and after that arduino will print "Fingerprint Work Fine"
char *token = strtok(inData, ","); // Get the first token
////////while(token)
   values[index] = atoi(token); // convert the token to an int and store it in the array
   index++; // Increment the index
   token = strtok(NULL, ","); // Keep parsing the same string
if i disable while and make it comment the code will work fine :fearful:
can someone tell me what the hell is happen in this code :angry:
there is no link between while in IF statement not activated to executed and the function of fingerprint
getFingerprintIDez();
also if i remove the comment and remove the finger function getFingerprintIDez();
the code will work fine when i push the button and arduino stop print "Please Push buttion"
is there bugs in Arduino IDE compiler
i try version 1.6 and i have the same problem
this is the code
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char dataPacket[64];
char inData[64];
byte index;
int d=0;
int ss=0;
#include <Adafruit_Fingerprint_MEGA.h>
int getFingerprintIDez();
#define mySerial Serial1
Adafruit_Fingerprint_MEGA finger = Adafruit_Fingerprint_MEGA(&mySerial);
int buttonState = 0;
const int buttonPin = 2;
void setup(void)
  finger.begin(57600);
void loop(void)
   buttonState = digitalRead(buttonPin);
  if (d==0){
    Serial.println("Please Push Button");
    if (buttonState == HIGH) {
   d=1;
  if(d==1){
  if(ss==1){
    Serial.println("System Work Fine");
   // Read all serial data available, as fast as possible
  while(Serial.available() > 0)
    char inChar = Serial.read();
    if(inChar == SOP)
       index = 0;
       inData[index] = '\0';
       started = true;
       ended = false;
    else if(inChar == EOP)
       ended = true;
      if(index < 63)
        inData[index] = inChar;
        index++;
  // We are here either because all pending serial
  // data has been read OR because an end of
  // packet marker arrived. Which is it?
  if(started && ended)
    // The end of packet marker arrived. Process the packet
 int values[10]; // Array to hold the values
byte index = 0; // index into array
while(token)
Serial.println("---------");
sprintf(dataPacket,"%d,%d,%d,%d,%d,%d,%d,%d,%d,%d",values[1], values[2], values[3], values[4], values[5], values[6], values[7], values[8], values[9]);
      Serial.println(dataPacket);
Serial.flush();
    // Reset for the next packet
    started = false;
    ended = false;
    index = 0;
 uint8_t p = finger.getImage();
 if (p != FINGERPRINT_OK)  return -1;
 p = finger.image2Tz();
p = finger.fingerFastSearch();
  switch(finger.fingerID){
      case 0:
   Serial.println("Finger Work Fine ");
   mySerial.end();
   Serial1.end();
  d=2;
  ss=1;
  return finger.fingerID;
Just modified your code slightly to turn it into something to debug.
int values[30];
char inData[]={"12,13,14"};
Serial.begin(57600);
int index=0;
while(token)
   Serial.println(values[index]);
void loop(){}
Here's my output
12
13
14
Seems your problem is not in the snippet you posted.
i didn't find any reason for what happened
why when i disable while the fingerprint run
while located in if statement and its not activated till i scan my finger ? :confused:
also i connect an xbee to arduino and send string to another xbee connected to atduino and i received it with out any problem using the code i posted it
but with out putting in in if and fingerprint :grin:
so the problem is not in code of receiving
also when i remove finger print from code the code work very well
It would appear that you have a problem building the inData string or initialising index or maybe your values array has a problem. But I'm just shooting in the dark.
im trying to convert while in function out of the loop then call it but i got this error
#define SOP '<'
#define EOP '>'
bool ended = false;
char inData[64];
byte index;
int d=0;
int s=0;
int ss=0;
char n=0;
const int buttonPin = 2;     // the number of the pushbutton pin
void setup(void)
void loop(void)
  if (d==0){
   d=1;
  if(d==1){
  if(ss==1){
    Serial.println("x");
    if(inChar == SOP)
       index = 0;
       started = true;
       ended = false;
       ended = true;
      if(index < 63)
        index++;
tokken();
sprintf(dataPacket,"%d,%d,%d,%d,%d,%d,%d,%d,%d,%d",values[1], values[2], values[3], values[4], values[5], values[6], values[7], values[8], values[9], n);
Serial.flush();
    started = false;
    ended = false;
    index = 0;
byte tokken(int values[10], byte index = 0)
  while (token)
 //  int values[10]; // Array to hold the values
  // byte index = 0; // index into array
      case 0:
   mySerial.end();
   Serial1.end();
  d=2;
  ss=1;
  n=1;
That isn't an error. That is code. Try again.
hi paul
you remember when i ask for help to send string and split it into array after receiving it via xbee
in this code i put security level fingerprint with button
but there is problem in execution as i explain in the posts upper and i can't solve it because i don't understand why it happen
In your function byte tokken(int values[10], byte index = 0) you make reference to a variable called token But the only place you define this variable is within your loop function.
So token is a local variable to your loop function. You don't have access to it within your tokken function. This is what "not declared within this scope" means.
The other errors mentioned seem pretty similar.
thank you KenF for explain that
i edit the code again and put all the xbee code in function and put this function out of the loop and call it from the loop and this time the code work fine without any problem.
fingerprint work fine and xbee receive the string from another xbee and adrduino split it and show it in serial monitor
this is the new code
#define SOP '<'
#define EOP '>'
bool ended = false;
char inData[64];
byte index;
int d=0;
int s=0;
int ss=0;
char n=0;
void setup(void)
void loop(void)
  if (d==0){
   d=1;
  if(d==1){
  if(ss==1){
    //Serial.println("x");
    xbe();
int xbe(){
    if(inChar == SOP)
       index = 0;
       started = true;
       ended = false;
       ended = true;
      if(index < 63)
        index++;
while (token)
Serial.flush();
    started = false;
    ended = false;
    index = 0;
      case 0:
   mySerial.end();
   Serial1.end();
  d=2;
  ss=1;
  n=1;
can someone tell me please why the code didn't execution before i put it into a function
it execute only when i remove fingerprint function
or make while(token) comment
i want to know if someone have background in programming please give us some explain and info to understand
don't tell me there is no one know why this error happen :fearful:
i just want to learn more, i hope someone come from those who a good understand in programming to tell me the reason :grin:
If you send me your Arduino and fingerprint scanner, I'll take the time and trouble to investigate the two codes to see what the real differences are. Without them, and knowing that you have code that works, the motivation (and ability) just isn't there.
If you're willing to buy another finger print scanner I'll make you the same offer as PaulS. I suspect that, all you'll get from our labours is a forehead slapping "doh" moment.
these days i cant buy the fingerprint with Arduino
but i do that soon and I'm really interested to learn from you Pauls and KenF
Haider92:
Seriously. Reverse engineering somebody else's code is work. If they have a real problem I'll sometimes do it to help a fellow man out. More often than not, once I find the error it's some silly detail that the original poster has overlooked. But to find that requires me to work out how the heck the sketch is supposed to work in the first place. To do that I would have to download the library files you're using and go through them to understand them. When the nett result is just you getting to say. "Oh yeah, I should have seen that!" It's just not worth it.
Just be happy that what you have now, does what you want. You also have the treasure of a little mystery that you can look at, whenever you're lost for something better to do.
Thank you KenF for details and motivational words :slight_smile:
