interfacing digital compass
Hello, I have recently purchased my own arduino mega and I have problems regarding interfacing with a digital compass ( OS - 5000 US ).
This is my Source Code :
#include <SoftwareSerial.h>
#define rxPin 52
#define txPin 53
SoftwareSerial CompassSerial(rxPin, txPin);
int compass;
pinMode(txPin, OUTPUT);
pinMode(rxPin, INPUT);
CompassSerial.begin(19200);
}[/i]
compass = CompassSerial.read();
Serial.println(compass);
I have tried the rs232 shifter from sparkfun, and have not been able to get any output. Is this a connection problem on the hardware part or is there a problem with my program.
Thanks in advance.
Have you tried connecting it to something you know works, like a PC serial port?
Try making sure data is available first before reading it, else you'll be printing lots of "garbage" data:
if (CompassSerial.available()) {
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
Hello, thanks for your replies, I have updated my sketch after reading up on the product a bit more however I'm still unable to get an accurate reading for Gyro Outputs ( X & Y ) and Total Gyro Output
This is my sketch:
#include <NewSoftSerial.h>
#include <string.h>
#include <ctype.h>
#define rxPin 4
#define txPin 5
NewSoftSerial CompassSerial(rxPin, txPin);
int byteGPS=-1;
char linea[300] = "";
char comandoGPR[6] = "$OHPR";
int cont=0;
int bien=0;
int conta=0;
int indices[13];
int i = 0;
int j = 0;
  CompassSerial.begin(9600);
  for (int i=0;i<300;i++){       // Initialize a buffer for received data
    linea[i]=' ';
  if(CompassSerial.available()) {
    byteGPS = CompassSerial.read();
    if (byteGPS == -1) {           // See if the port is empty yet
      delay(100);
    else {
      linea[conta]=byteGPS;        // If there is serial port data, it is put in the buffer
      conta++;
      if (byteGPS==13){            // If the received byte is = to 13, end of transmission
        cont=0;
        bien=0;
        for (int i=1;i<6;i++){     // Verifies if the received command starts with $GPR
          if (linea[i]==comandoGPR[i-1]){
            bien++;
        if(bien==5){               // If yes, continue and process the data
            if (linea[i]==','){    // check for the position of the  "," separator
              indices[cont]=i;
              cont++;
            if (linea[i]=='*'){    // ... and the "*"
              indices[12]=i;
              cont++;
          Serial.println("");      // ... and write to the serial port
          Serial.println("");
          Serial.println("---------------");
          for (int i=0;i<4;i++){
            switch(i){
            case 0 :
              Serial.print("Heading(Degrees): ");
            case 1 :
              Serial.print("Pitch Angle(Degrees): ");
            case 2 :
              Serial.print("Roll Angle(Degrees): ");
            case 3 :
              Serial.print("Temperature(C): ");
            case 4 :
              Serial.print("Depth(ft): ");
            case 5 :
              Serial.print("Acceleration Vector Length: ");
            case 6 :
              Serial.print("Acceleration Reading(X): ");
            case 7 :
              Serial.print("Acceleration Reading(Y): ");
            case 8 :
              Serial.print("Acceleration Reading(Z): ");
            case 9 :
              Serial.print("Total Gyro Output: ");
            case 10 :
              Serial.print("Gyro Output(X): ");
            case 11 :
              Serial.print("Gyro Output(Y): ");
            default :
            for (int j=indices[i];j<(indices[i+1]-1);j++){
              Serial.print(linea[j+1]);
            Serial.println("");
        conta=0;                    // Reset the buffer
        bien=0;
        cont=0;
          linea[i]=' ';
Thanks for all your help.
I have a sample of the output here :
http://img826.imageshack.us/img826/8978/screenshotrk.jpg
PS: If I'm in the wrong forum can someone help me move this thread to the correct one?
I'm not too sure software serial can do serial.available?
SoftwareSerial can't, but NewSoftSerial can and does.
