Wire.beginTransmission(I2Cadd);
Wire.send(GPIOA);
Wire.send(0xF0); //trying to connect 2 led with diff pin to test.
Wire.endTransmission();
delay(2000);
please help, i've been working on this for 2 weeks.
thanks.
chen
Actually it looks like the problem might be pretty obvious. In I2C you can't just keep sending addresses and then data, the chip has no idea what you are trying to send it. The MCP23018 will auto increment addresses after each byte (unless the SEQOP register is disabled). That means you're writing register addresses into the MCP23018 registers instead of addressing the registers and putting your intended data in them. Either start with one address and then write a long stream of sequential registers, or break each register access into a separate I2C conversation.
You can also use the Centipede Library and example code as a start, it'll work with MCP23017 or MCP23018 chips, not just the Centipede Shield: centipede_shield [macetech documentation]
I think several other people have made libraries for these chips too. Search around the forums....
To simplify what macgr is saying, you need to call Wire.endTransmission after every pair of register/data writes, and then Wire.beginTransmission again. Unless you are writing data in order to sequential registers.
#include "Wprogram.h"
#include "MCP23017.h"
byte MCP23017::Read8 (byte mcpregister) { // read 8 bits from MCP register;
byte controlbyte = B0100000 | i2cAddress; // note that bit 0 not used b/c 7-bit opcode for Wire library
byte tempdata;
Wire.beginTransmission(controlbyte);
Wire.send(mcpregister);
Wire.requestFrom(controlbyte,(byte)1); // otherwise function gets one byte and one int & chokes
while (Wire.available() < 1) { }
tempdata = Wire.receive(); // get lower 8 bytes
return tempdata;
word MCP23017::Read16 (byte mcpregister) {
word tempdata;
Wire.requestFrom(controlbyte,(byte)2); // otherwise function gets one byte and one int & chokes
while (Wire.available() < 2) { }
tempdata |= (Wire.receive() << 8); // get upper 8 bytes
return tempdata;
void MCP23017::Store8 (byte mcpregister, byte mcpdata) // Store 8 bits in specified register of MCP23017
Wire.send(mcpdata);
void MCP23017::Store16 (byte mcpregister, word mcpdata) // Store 16 bits in specified register of MCP23017
Wire.send(loByte(mcpdata));
Wire.send(hiByte(mcpdata));
Declare an instance of MCP23017 and set its i2cadress to use. I.e.:
MCP23017 expander;
expander.i2caddress = 0x20;
expander.Store8(IOCON,0xA4);
expander.Store8(IODIRA,0x00);
etc.
