Interfacing MT8870 DTMF decoder with Arduino Mega 2560
How to connect the 4 BCD output of the MT8870 to the arduino so that a particular relay can be controlled when a specific button is dialed? Thanks
datasheet link?
MT8870 is a dtmf decoder.. here is the link to its data sheet:
http://www.siongboon.com/projects/datasheet/data%20communication/mt8870,dtmf%20decoder.pdf
Here is some code for an Arduino (written for the NG, IIRC) and here is a schematic that may or may not go with aforementioned code. (most likely difference is the reversal of Q1-Q4 due to upside-down mounting of my SMT 8870 on a single sided PCB).
Note it uses direct port manipulation (PORTD) and interrupts.
-j
Thanks...but could u kindly tell me how can i interface MT8870 with my Arduino Mega 2560 board and how to program so that i can turn on or off a realy when a particular BCD is generated? A circuit diagram will be highly appreciated.
google is your friend:
http://w2mh.wordpress.com/2010/06/03/dtmf-shield/
try something like 'mt8870 arduino' in the search line and then start clicking. People aren't going to design and build it for you; do some work up front, then ask specific questions.
Thank You.
If you want to save your arduino for something else.
http://www.rainbowkits.com/kits/TT-16p.html
Is it possible to reset the DTMF signal after the mobile phone button is released ?
Please Help !!
