Interfacing my baking oven lamp
I would like to build a small device to make my baking oven "smart" and let me know, once the pre-heating is done.
My oven has a 230V lamp which lights up as long as the oven is pre-heating. Once the heating is done, the lamp turns off.
Do you have any suggestions how to let my Arduino know, if the lamp is on/off? The solution should not be optical, I don't want the device to be visible from the outside (no photoresistor on top of the lamp).
I though about something like an ACS712 current sensor to put in the line to the lamp? Or using an optocoupler?
Thanks!
A current sensor will work well. Make sure you pick one that can measure the small current of your light well (such a lamp can be as small as 1-2W, which would be about 5-10 mA).
Any optical solution would have to deal with the heat of the oven itself... that alone makes it a poor solution here :slight_smile:
I wouldn't recommend installing things inside an oven. The higher temperature there makes everything age fast, isolation gets fragile and kracks…..
The switching of the lamp is often done by a mechanical temperature sensor that makes a noticable "click" when it switches. Maybe that could be picked up from the outside?
I am confused why your concerned with the little light.
Presumably, when the “little light” turns off, the entire oven will have a significant power reduction.
Could you just put the AC current sensor on the main power cord to the appliance ?
mexxle:
Thanks!
Requirement contradicts itself.
Invasive...relay across the lamp
Non-invasive.... thermistor clamped to the exterior of oven internal case.
bluejets:
OP asks for "invisible from the outside", not "invasive". A current sensor inside the oven's outer shell is invisible from the outside, and thus fits the requirement.
wvmarle:
Op asked for ideas.
I...supplied one invasive solution and one none invasive solution.
Nothing to do with being invisible.
