Hello All, Greetings.
This is my first post in this forum, I have been learning arduino with help of this forum for few years, Now I have to repair a Thermal printer for my friend. There is a Reflective Object Sensor on that Printer to identify when paper is empty.
As per the name on the Sensor, it is OPB706A sesnor with photoelectric transistor. As I am not into electronics field, I dont have an Idea how can I connect this sensor to arduino to get either digital or Analog input.
I have attached datasheet for the said sensor.
Can you please help me ,
Thank you very much.
Shafeeq
Hallo Larry,
Thank you very much for the support, When I have checked the sensor, It is mounted on a PCB with 3 Wires Coming out. The connection is as Follows
Red Wire- Pin 1 of Sensor (collector of Transister)
Brown Wire- Pin 4 (Cathode of diode) and Pin 2 (Emitter of Transister)
Orange Wire - Pin 3 (Anode of diode)
So I can´t connect as you have mentioned.
Something like this will work:
Thank You very Much,
Can you please tell me what you mean by From Output?
That is an optocoupler input, that might typically come from an Arduino output.
Thank You very much, Please find the below photos, There is no Resistors Integrated,
Please have a look, Unfortunatly, I couldnt focus on PCB
