Interfacing RD530 Bluetooth card with Arduino
Hello! I am trying to interface an Arduino with an RD530 Dell Bluetooth card from a laptop so I can use it as a Bluetooth module to transfer and receive commands, so I need your assistance on whether it is possible for what am trying to do to work. I have attached an image of the pin out of the Dell Bluetooth card. Thanks in advance
Normal Bluetooth operation with Arduino requires four pins: Vcc Gnd Tx Rx.
This device has ten pins, so the first job is to eliminate six, and it looks like you can do that speculatively, leaving pins 1,2,3,8. Pins 1,8 are obvious enough, and pins 2,3, in the absence of any other suggestion, are likely to carry the data. All you need do is work out how they are used to do that. You might conclude that spending $3 on a device that you can expect to work first time is a pretty good idea.
@ngalande
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
