Hi everybody...
For Graduate I want interface SCP1000 and Max/MSP, I' ve chose the Maxuino 007 maxpatch in max.
Maxuino requires on arduino the Standard Firmata 2.1, i can't modify it whit the code i have found in this forum for the SCP1000.
How can I include this code in the firmata to receive in Max/MSP the SCP1000 temperature and pressure??
I have now except from firmata the digital pin from 2 to 5, to connect the sensor, and included the variables for it but i can't redirect the spc1000 data to the usb serial whit all firmata data, i can't include the code in the firmata.
Please Help me!!
SCP1000 Original Code
// define spi bus pins
#define SLAVESELECT 10
#define SPICLOCK 13
#define DATAOUT 11 //MOSI
#define DATAIN 12 //MISO
#define UBLB(a,b) ( ( (a) << 8) | (b) )
#define UBLB19(a,b) ( ( (a) << 16 ) | (b) )
//Addresses
#define REVID 0x00 //ASIC Revision Number
#define OPSTATUS 0x04 //Operation Status
#define STATUS 0x07 //ASIC Status
#define START 0x0A //Constant Readings
#define PRESSURE 0x1F //Pressure 3 MSB
#define PRESSURE_LSB 0x20 //Pressure 16 LSB
#define TEMP 0x21 //16 bit temp
char rev_in_byte;
int temp_in;
unsigned long pressure_lsb;
unsigned long pressure_msb;
unsigned long temp_pressure;
unsigned long pressure;
byte clr;
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK,OUTPUT);
pinMode(SLAVESELECT,OUTPUT);
digitalWrite(SLAVESELECT,HIGH); //disable device
SPCR = B01010011; //MPIE=0, SPE=1 (on), DORD=0 (MSB first), MSTR=1 (master), CPOL=0 (clock idle when low), CPHA=0 (samples MOSI on rising edge), SPR1=0 & SPR0=0 (500kHz)
clr=SPSR;
clr=SPDR;
delay(10);
Serial.println("Initialize High Speed Constant Reading Mode");
write_register(0x03,0x09);
rev_in_byte = read_register(REVID);
pressure_msb = read_register(PRESSURE);
pressure_msb &= B00000111;
pressure_lsb = read_register16(PRESSURE_LSB);
pressure = UBLB19(pressure_msb, pressure_lsb);
pressure /= 4;
Serial.print("PRESSURE [");
Serial.print(pressure, DEC);
Serial.println("]");
temp_in = read_register16(TEMP);
temp_in = temp_in / 20;
temp_in = ((1.8) *temp_in) + 32;
Serial.print("TEMP [");
Serial.print(temp_in , DEC);
delay(1500);
char spi_transfer(volatile char data)
SPDR = data; // Start the transmission
while (!(SPSR & (1<<SPIF))) // Wait for the end of the transmission
return SPDR; // return the received byte
char read_register(char register_name)
char in_byte;
register_name <<= 2;
register_name &= B11111100; //Read command
digitalWrite(SLAVESELECT,LOW); //Select SPI Device
spi_transfer(register_name); //Write byte to device
in_byte = spi_transfer(0x00); //Send nothing, but we should get back the register value
delay(10);
return(in_byte);
float read_register16(char register_name)
byte in_byte1;
byte in_byte2;
float in_word;
in_byte1 = spi_transfer(0x00);
in_byte2 = spi_transfer(0x00);
in_word = UBLB(in_byte1,in_byte2);
return(in_word);
void write_register(char register_name, char register_value)
register_name |= B00000010; //Write command
digitalWrite(SLAVESELECT,LOW); //Select SPI device
spi_transfer(register_name); //Send register location
spi_transfer(register_value); //Send value to record into register
